Question about Sony FD Trinitron WEGA KV-36HS420 36" TV
Wording permanently on screen
The words "Video 5" remain permanently on the television screen. I can scroll through all the Video numbers, the wording remains on the screen. I've unplugged and replugged the television from the power source.
  • Pam Matteson Oct 31, 2006
    Oops....
    I spoke with Sony Tech Support in an online chat last night. It was suggested I phone for service.
    Before the serviceman drove out to our house today he suggested I put my Sony remote control in the TV mode (it had been in satellite mode) and hit the Display button.
    The green "Video 5" immediately disappeared from the screen.
    Well THAT turned out be be an easy fix!
I realy dont know how to take the video 2 when I play video games n I dont have the remote but theres a control key on the tv so can a ny body help me take it off pllllllzzzz
Posted on May 21, 2011
What if you can't find your sony remote? how do you get it to go away?
Posted on Oct 13, 2008
I've suffered through this for 2 years and finally decided to look up a solution. Problem solved hitting the info button while in tv mode of universal remote. Thank you.
Posted on Jan 05, 2008
I have had this problem all along with my Sony, not being able to figure out how to get rid of the Video 1 setting! I read this posting from Kessa a few minutes ago, and I tried hitting TV and Display - I couldn't find Display - it was because I had picked up the wrong remote! I had the Comcast remote instead, and when I couldn't find Display, I pressed Info - and it disappeared! Then I realized I had the wrong remote. I tried this process again using the correct Sony remove - I hit TV and then Display and it did work! Yay! thank you so much.
Posted on Sep 26, 2007
How to change text size
please clarify; what kind of operating system your using? text size of what? application software like word or Computer screen display? for windows screen text you can enlarge by entering control panel-appearance and personalization for win7&win8 - display make item small or larger or by changing screen resolution
May 01, 2014 | HP Mini 1000 Netbook
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Jun 07, 2013 | Televison & Video
Video 5 wording stays on the screen
Either change input or hit display button on the remote to remove it from the screen.
Nov 16, 2011 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
How do I remove close caption wording on my tv screen??? (Insignia 42" TV don't know model number.)
Here is a manual for a 42" Insignia. Hopefully it's similar http://insigniaproducts.com/cms/documents/NS-42LCD%20UM%20EN_SP_FR.pdf
This one says the closed caption settings are in the "system setup" menu.
Feb 11, 2011 | Insignia LCDTV26 26 in. Television
Wording can't be seen on t.v
the words may seen the screen when u set it in caption mode. try search that in tv manual.
Jun 20, 2010 | Vizio L37 Television
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Suggested wording for text messages
Above the numbers on your phone is a circle with 4 arrows, one pointing in each direction.....when the word that you want appears on your screen push the arrow that points right. It will then put the word into your text message and skip a space so that you can begin the next word
Feb 07, 2009 | Motorola Mobility RAZR V3
Are there internal picture controls for the WS-55315?
Good Day; OPTION MENU "MENU 0370" SERVICE MENU. CAUTION document settings before any adjustments are made. V = vertical, H = Horizontal. Good Luck, big IRISH.
May 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Philips Home theater system
Just run the yellow cord that came supplied with the HTS from the CVBS plug in the back of the HTS to any available yellow video input on your TV, then you want to change your TV's video/source/input/channel (the wording varies by tv manufacturer) to Video 1/AV 1/Aux 1, or whatever your television is calling the yellow input that you plugged into.
Also, Philips number is 1-888-PHILIPS
-Tha Mp3 Doctor
Jan 12, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Sony FD Trinitron WEGA KV-36HS420 36" TV Logo
399 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
