Hi there everyone i have bought my first cagiva mito year 2000 i bought it as a non runner when you press the start switch some times it turns over sometimes it wont i have checked all the wires and conections and all seem fine on the times it does decide to turn over there is no spark . on the starter relay it has 4 prongs coming out of it with made in italy 89846 on the top of it but the plug it goes into has 5 termainals nothing is conecting to the one in the middle could someone shed some light on this for me
i have the same problem got new regulator still nothing mines the 91 lucky explorer this problem is driving me nutsi have the same problem got new regulator still nothing mines the 91 lucky explorer this problem is driving me nuts
You can't post conmments that contain an email address.
Cheers for any helpBasic test on the system can be done with a $10 multi meter.
You need voltage of 12.4 or so in system with battry no lights ignition off, static test.
Then with motor running voltage should run up to 14.2-14.5 volts which is what mine does.
Battery never goes flat.
If this does not happen substitute another reg!
See if there is a change.
get creative and look on ebay .
GBP5-10 or ask Col?
heaps in Germany on 'bay
Charging the easiest thing on Mito to fix.
Regulator just normal Ducati type .,,,
cheers for any helpSeems odd normally like mine there is a starter solenoid??
I got odd starting problems, I think solenoid.
You should have a big 12v in and out. The plug in centre should carry a signal from the switch to initiate the solenoid and give the starter its voltage.
Try checking this with a multimeter.
I also found the connections under the dash/behind headlights were SERIOUSLY corroded, could be worth checking.,,,
