Question about Sharp 27C-240 27" TV
Sharp 27" tv
I bought a sharp 27" tv about 5-6 years ago. I am getting very bad reception on the lower channels on 2 & 5. when I place the TV on channel 3 and use the vcr to tune and change channels it works fine. Does this mean my internal tuner is going bad and if so is it time to buy a new TV.
    Sergeant:
  • 337 Answers
You got the right idea,use the ext.imput on you tv and use the vcr to change the channels,you can check the solder conections in the tuner ,ussually the ground gets loose after a while but if you are not too familiar with tv service and dont want put any money in this set use your vcr.If the quality of the picture is still good then is worth keeping it.Let Us know if you need more information.
Posted on Oct 30, 2006
  • Omar Urrutia
    Omar Urrutia Oct 30, 2006
    your rating response is also important.
Pitcure and usb problem
usb is shorting out the 5 volts. as its only 2 months old would take it back to the place you bought it and get a replacement.
Mar 02, 2018 | Philips 27PT81S 27" TV
Problems on the freeview 21inch Tv Teknica from Tesco was working when we bought it 2 years ago cannot get all the channels and poor reception re installed channels many many times but does not maintain...
you may want to try changing the coaxial aerial cable that feeds the tv, these can go faulty. also if you are running a series of tvs off one aerial, you should be using an aerial booster, other wise you will get a signal drop (as displayed on your tv).
If these small things don't cure it, the set requires replaceing as the tuning card is knackered
Jan 16, 2011 | Audio Players & Recorders
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Channels
they passed a law a couple years ago, see now you have to BUY cable... right now ur just gettin what ever the antenna on ur tv picks up. buy cable or dish or somethin and u get like 70-150 channels
Jul 30, 2008 | Televison & Video
TV gets stuck on channel, won't advance past channel 7.1
Try doing the Channel Search again. See if that helps.
If not, sounds like the Digital Board could be defective. Since this TV is brand new suggest calling your local sharp authorized service center to replace that board under warranty.
Mar 16, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
RCA F27664 27" TV Problem: HELP
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Channel reception lost if tuner socket moved
Dry joints on IC522, IC521 and IC541 (located in the big heatsink about middle of the main pcb)
Nov 24, 2007 | RCA F27664 27" TV
Some channels not programable
Bad tuner = verify part # from back of set to get part #...
Let me know..........................T.
Nov 22, 2007 | JVC AV-27D303 27" TV
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
Missing channels
no they are not related. ur tv seems to have a defective tuner(inspect also for possible cold solder inside the tuner). remote control can be clean using a cotton swab with a little isoprophyl on it. clean the contact on the pcb.
Jan 14, 2007 | Samsung TXN2745FP 27" TV
Sharp 27C-240 27" TV Logo
73 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
