Question about Philips Magnavox TS3260C 32" TV
Problems The tv turns on, there are horizontal lines. within 1 minute, its shuts itself off. what is going on
  • 337 Answers
The set is missing a voltage in the crt board,a resistor with a value of 51 ohm has opened for no reason ,all you need to do is change this resistor and is all is going to take,if you are familiar with tv service you can unplug the set and remove the back cover,in the neck of the picture tube you will see the crt board ,look for R56 and he should measure 51 ohms and its color code is blue/brown/black and is 1/2 watt,it needs to be replaced with an exact replacement.You dont need to remove the board from the tube ,if you do make sure you pull straight back and dont twist the board or some of the pins might break and then we will have a big problem.If you are not too familiar with tv service you should call for assistance from a servicer,it should not be expensive.Let Us know if you need more information.
Posted on Oct 30, 2006
  • Omar Urrutia
    Omar Urrutia Oct 30, 2006
    Your rating response is also important.
  • Omar Urrutia
    Correction in the color code,it should be green,brown,black.
Horizontal lines samsung lcd tv, then more horizontal lines, then complete static out, TV restartes itself. after a 5 minutes or so, it seems fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 04, 2015 | Samsung Televison & Video
My tv will turn on but with white light line then shut off itself
If the line is horizontal (it is a vertical problem) If its a Vertical line (it a horizontal problem) So it could be just a bad solder joint or a component has failed in the horizontal or vertical section. Hope this is helpful.
Nov 28, 2009 | Philips Magnavox 27MS343S 27" TV
Will not turn on. Shuts off immediately after turning on.
Sounds like the vetical deflection went out. Most likely have a leaking picture tube and the cooling fluid has goton on the board so you would be beter to replace if that is it.
Sep 03, 2009 | Mitsubishi VS-55707 TV
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
May 17, 2008 | Hitachi 36UX59B 36" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Dec 03, 2007 | Sony KV-36XBR400 36" TV
Red screen
sounds like a picture tube problem its a problem that probably cant be fixed only by a professional
Nov 30, 2007 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi Projection TV. Works for a couple of hours and then the picture shuts off
Very often older Mits CRT's develope a slow leak of coolant
onto one of the circuit boards....various problems arise,depends
on where the drip lands....even a good tech can miss the drip
evidence.....I have pulled the chassis to the shop only to find
"wet" area under well-lit conditions.................T.
Nov 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
RCA F36674ET - Only beeps when turned on
Clearly shows problem in deflection area both horizontal and vertical section. Horizontal lines is due to vertical section problem and making bbzzzz is due to horizontal output transistor short and sometimes LOT SHORT.
Aug 23, 2007 | RCA F36668 36" TV
Philips Magnavox TS3260C 32" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
