Question about JVC XV-FA90 Multi-disc DVD Player
Picture on tv screen is split
When I turn on the power it displays "loading" then when it loads the disk to play, it projects side by side split screen images in black and white. I use the audio/video cables to the television. never had any problems before.
5 Suggested Answers
SOURCE: No Colour
I am trying to learn the Lexmark 1200 printer, am very new at this. Tried to copy my first photo but it keeps coming out pink, what am I doing wrong? Is this the best I can expect?
Posted on Jan 16, 2007
  • 3 Answers
SOURCE: JVC DVD player stuck in Split screen
the player is set to progressive scan mode.use relevant button on remote to reset to interlace mode. Duane,S/Africa
Posted on Sep 01, 2007
ice man
  • 68 Answers
SOURCE: Help - loads with this problem....
check the setting and make sure you have the right format for playing and the out put of the machine.
Posted on Jul 17, 2008
SOURCE: Split Screen Output
check on the remote if got some function of format ntsc or pal or check on the menu of the dvd
Posted on Oct 31, 2008
  • 6 Answers
SOURCE: image split with black bar in middle
check leads if they are connect in the normal video slot on dvd player and chek the player settings what out pot it is on
Posted on Aug 22, 2009
0 characters
1 Points
My LG RH397D will not play a disk. It gives a navigation error.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
    See the diagram attached.and if the problem persist. Lube the plastic parts with small grease or vaseline very carefully
Feb 09, 2013 | DVD & Blu-Ray Players
I just finished running the cleaning disk and the player runs and says loading but dvd will not play. No picture on the tv?
Some dvd players simply will not play copies of dvd's, or ones made on a computer.
Another thing to try, is to unload/eject any discs, turn off the player, unplug from AC socket for a minute or two.....and then re-plug, and turn it on, load a disc, and see what happens. Hope this helps.
Apr 09, 2010 | DVD & Blu-Ray Players
Samsung DVD-V8600.....DVD won't load
open cover and clean the laser with alcohol and try again
Mar 13, 2010 | Samsung DVD-V8600 DVD Player/VCR
Dvd in player but display says no disk
Check the regional code of the DVD you want to play. It is at the back of the DVD cover. It should be compatible with the regional code which your DVD player can play. If they are not tallying the disc will not be read
Feb 23, 2010 | Toshiba SD-K760 DVD Player
Dvd player split screen
I had the same problem. It turned out to be my cable that went from the dvd player to the TV. I replaced with new cable & everything worked fine again. Hope this helps & please remember to rate my answer. Thanks.
Feb 06, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
No picture on tv when i turn on dvd. get split screen black & whi
Give this a try. Using your user's manual, locate the "Configuring your recorder" section. Under this section there will be "System setup - general" subsection. Being that you are unable to see anything on your tv display you will need to use your manual as your display. Press the "SETUP" key on your remote. Once again using your manual as your display, scroll down to "Restore factory settings" and press "ENTER" As long as you are located in North or Central America and using interlaced video outputs you should have your normal display back.
Hope this helps.
Nov 24, 2008 | Protron PD-DVR100 DVD Recorder
No Disk
When I try to play a DVD, operation seems normal, the unit makes a slight noise like the disk is rotating and "Loading" is displayed. Then after about 30 seconds the message "No Disk" is displayed. Then just the Polaroid screen is displayed. I have lost the remote control but surely the unit will play using the front panel buttons. One thing, only the remote is named as having a Setup Button in the manual but the unit has no such button.
Apr 12, 2008 | Polaroid PDV-0813A
GPX DVD Player
I have a split screen
Nov 15, 2007 | GPX D1816 DVD Player
JVC XV-FA90 Multi-disc DVD Player Logo
19 people viewed this question
Top JVC DVD & Blu-Ray Players Experts
Are you a JVC DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
