Question about RCA F36648 36" TV
Changing changes without notice
I just received this TV. the TV changes channels on it's own. kind of like if your sitting on the remote (but of course we're not). does anyone know if this is an easy fix or something I need to take to a shop to fix.
    Sergeant:
  • 337 Answers
The easiest thing to check is if the channel up or down buttons are not pushed in too far forcing the switch to make contact all the time,the other possible reason is some of the cleaning solution or water might have gone down to the buttons and creating a short making the switch active all the time.For this reason you will need the help of a servicer to find you the parts and replace them.Let Us know if you need more information.
Posted on Oct 30, 2006
  • Omar Urrutia
    Omar Urrutia Oct 30, 2006
    Your rating response is also important.
My remote wont work called about 3 weeks ago for replacementno response... and my tv is changing channels on its own,
You have to get nasty with the manufacturer at times to get what you want. No reason a remote can't be replaced in a few days; however, the problem seems to be the TV itself. If the remote is not active, and you experience channel changes automatically, it may be the TV receiver section alone. Call the company and mention that without the remote energized you have channel changes, they can run you through diagnostics to find the problem.
Feb 04, 2018 | Televison & Video
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
Why does my fireplace insert go on and off when I cchannel my tv remote up and down any solutions please and thank you
Samsung Anynet+ switching input modes when tv is turned on ...
www.cnet.com > Forums > Samsung
CNETMy recommendation would be to hook an Anynet+ device up directly to ... My TV (HDMI IN 1) is connected directly to my receiver with an HDMI cable ... Without that connection connected, it will by default go to the blank screen you're describing. .... I just want the anynet function to know that the dvd is turned off and to switch ...
tv remote turns on fireplace.. Help!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Feb 25, 2014 - we just got a vizio smart tv and it sits on a electric fireplace but every ...on the tv remote it turns on/off or changes the heat temp my fireplace!!! ... the makers of electronics such as televisions and receivers do go out of ... A/C remote and it might change channels on the TV or raise the volume ... Thumbs down.
Your remote reprogramming woes solved - Rogers RedBoard
Dec 15, 2015 | Heating & Cooling
I cant figure out how to change the channel to input/video on my broadband tv without a remote
This problem may be more complex than just the selection of a channel to receive video. The first problem is what channel to receive the video. Usually its received on channel 3 or 4. You select that on the video output and match it on the TV. That assumes your recorder is attached via the RF (antenna) connection. If its hooked up via the component connect then you must have a remote to select IN1 or IN2 on the TV to receive video. Remote controls are available on line. Do a search on your TV model and remote control.
May 03, 2014 | Sylvania 6420FB 20" TV
This problem never happened before , We on the tv and the channels keep changing by it self . We are not touching any buttons and we even tried offing the tv and switching the power off . Each time we on...
As a test, block its (or the cable Box's) remote infrared sensor so even you can't change the channels with a remote. Then watch and wait. If it keeps happening, you have a poltergeist or a defective unit.
If not, something out 'there' is emitting infrared signals that the unit interprets as channel commands. Find the remote someone is sitting on or that guy across the street who's aiming at your TV with HIS remote.
Mar 06, 2011 | JVC Audio Players & Recorders
Need intructions how to program remote control on vip722k second receiver
Press and hold down the SETUP button located on the remote. Wait until the INDICATOR light turns on. It will blink once the button is pushed, however once you see the indicator light stay one, release the button. Click the button to the DEVICE you wish to program. If it is a TV, then click the TV button. If it is the cable box, then click CBL button. After doing so, the indicator should still stay on. Press the DOWN CHANNEL button several times until you see the RECEIVER yo wish to program respond. Example: If it is a TV, then you will notice the CHANNEL change once the remote locates the correct settings for that receiver. If you see the receiver respond and you are pushing the down channel button but nothing is working, it means you passed the internal settings of the remote to the receiver. Try pushing the CHANNEL UP button slowly. It may be able to relocate the the proper settings. Once you see the channel change again, press ENTER to program the remote. If this fails, retry the same steps. In some cases you may miss the correct internal settings.
Nov 23, 2010 | DISH Network IR Remote Control
My remote wont change channels
I need to use the cable remote to change the channel and the TV remote to change volume.
That is because your TV is looking at the output of the cable box (probably on channel 3 or 4) so the TV has to be statically tuned to see the cable box's output.
On the second question; I, and perhaps others, can't answer this without spending a lot of time to download manuals for both systems while you have them (presumably, since they are new) on hand. You didn't include the TV's model number anyhow so even that wouldn't be adequate.
The home theatre may have a receiver but what does it receive? Unless it also has channel capabilities that correspond to cable channels, it can't. The typical routing should be from the cable box to the TV S-video input and the sound can be routed separately from the cable box to either/or both, the home theatre's and also the TV's audio inputs.
When I am installing new stuff, I make a sketch of the routing I want (or have) to use. To me, this is less confusing than the supplied instructions.
Feb 01, 2009 | JVC LT-42X579 42 in. LCD TV
MY REMOTE WILL NOT CHANGE CHANNELS ONLY TURNS TV ON OR OFF
After much trial and error, we discovered a temporary fix. We taped a 3 x 5 index card to the front of the box directly to the right of the time/ channel number. The remote will change both the channels and the sound level with this "fix." Could there be some kind of emission coming from the box that interferes with the remote? Maybe Motorola could put a more opaque front on the box.
ympm
Jan 11, 2009 | Arris DCT6200 DTV Receiver
RCA F36648 36" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
