Question about Toshiba Satellite 2060CDS Notebook
Computer turns off by itself
My computer keeps turning off, and my dad said that it was the battery so it took the battery out and changed the settings and it still keeps turning off. It turned off twice in the last 10 minutes!
  • 1 more comment
  • Anonymous Dec 25, 2007
    keeps turning off when running on mains when i'm using programs like nero dvd srink an itunes
  • Anonymous Feb 15, 2008
    I"m having the same problem. Sometimes I can let my laptop run for days on end and have no problem, but then one day it will shut off. I keep a cooling pad underneath it that shoots the air up instead of pull away. It gets very cool underneath the laptop. Now sometimes when it shuts down, the clock and date are reset when I reboot, and the light that indicates that the battery is plugged in flickers on and off
  • Anonymous Mar 25, 2009
    Usually during cpu-intensive activities (gaming) or while watching movies, the same thing happens. The fan seems to be running fine. I wonder if it could be an issue with the heat sink?
    Problem Solver:
  • 7 Answers
I have a toshiba laptop which was unexpectedly switching off. The laptop was 2 years old. I did lots of searching online to discover this is a VERY COMMON ISSUE. The problem is, dust blocks the heatsink. When I took my computer to pieces, I found a strip of dust half an inch (1cm) thick covering the back of the heatsink which prevented air flow. If your laptop is a couple of years old, this could be the problem. When I removed this dust, the problem disappeared. If you are computer savvy, then try the following - if not, take it down to a computer shop! 1) Remove the 5 screws holding down the heat sink cover and processor cover. These are on the bottom of the laptop, in the centre, at the back. 2) Remove the 3 screws which hold in the heat sink in place. 3) Remove the heatsink 4) Take the dust out 5) Re-assemble a note: be careful not to get dust in the thermal paste on the cpu - unless you have replacement paste. Good Luck!
Posted on Aug 02, 2007
    Problem Solver:
  • 12 Answers
I have the exact same system. The problem I had (identical to this) is the adapter connection was loose on the motherboard (it was getting enough power to start the system but would turn off and would not charge the battery). Once the pins were re-soldered it worked fine.
Posted on Jul 21, 2009
Claudia with most toshiba larger notebooks the heatsink gets blocked and air will not circulate. When the computer reaches a specific temperature it shuts off.. a program called everest can check the temperature.. but my suggestion is that you take it to a person that is a+ certified to clean the heat sink coils
Posted on Mar 10, 2009
Computers have thermostats and my computer kept turning off because it was overheating. I had to replace one of the 2 fans which fixed it.
Posted on Aug 25, 2008
I have tjhe same problem my computer keeps on turning off but i dont think its beacuse of the fan it works perfectly ooh but it sounds a little weird
Posted on Mar 12, 2008
Hi, have a similar prob on an old presario 1700. SOB runs great in 80mb of ram with XP pro optimized... except the loss of power issue :( It doesn't have a built in wifi, so I put in pcmcia card. battery was dead, I replaced it ( now I get 4hrs out of a battery). Strange happens - System cuts off (screen goes blank, no power on wifi) although the power to the computer appears to be on and drive is spinning. I have to hold the power button for a few sec to actually turn it off (isn't it a sign that the system is still on? but the even manager doesnt' show a thing ! so i guess the sys is not on to record the errors...
Problem is unpredictable, I tried with or without battery, jiggled the power cord in the back etc... can't replicated it. I don't off but hte power is on! Everything I found online regarding somewhat issue is keeps saying dust, overheating .... I took mine apart and there is no sign of dust inside. I put some Arctic silver on CPU and mobo chip sinks I don't think it's overheating as sometimes it'll happen the first thing after booting up (the bottom isn't even warm) and sometimes after hours of watching a movie in bed (with vents closed) - testing overheating theory.
Maybe smdy can recommend another way of testing ?
Posted on Jan 01, 2008
It's overheating.  I have the same problem.  You might have to clean out the dust and gunk inside where your cooling fan is.
Posted on Oct 16, 2007
  • 32 Answers
1. Run the computer using only the AC adapter.
2. Reload the default settings in the BIOS.
3. Let the computer stay in the BIOS approximately at the same time the computer, according to you, will just turn off.
Posted on Oct 15, 2007
Maybe your power supply connector is bad and is not charging the battery. These connectors sometime break and do not charge the battery.
Posted on Sep 22, 2007
Actually I found out that my fan was messed up, adn it keeps going on an off so it overheats. also the powercord doesn't work great but If i don't move it it doesn't shut off. thanks tho
Posted on Sep 05, 2007
Toshiba extended the warranty for this or any problem your laptop has, but hurry up the extended warranty ends November 07
Posted on Sep 04, 2007
  • 57 Answers
Maybe the hibernation function...
    President:
  • 2,961 Answers
Maybe a overheating problem, have you noticed if the cooling fan cuts in every now and then. Does your pc notify you of anything before it shuts down, what was the last thing you were doing when it first started to shut down.
Posted on Oct 30, 2006
SOURCE:
Not turning on
try removing the battery and cleaning the contacts,,also check and make shure the charger is good
Jun 13, 2012 | LG KM555 Cell Phone
Hi, there i own dell latitude d620 when i press the power button it appear led power light and not boot, and it off itself why is this? please help me....
Remove the Battery then clean the metal contacts on the Battery and in the battery compartment then press and hold the power button on the Computer for 30 seconds.
Next, reinsert the Battery and try to turn ON the Computer. If the Computer keeps turning off then connect the AC adaptor to the Computer then try to turn it ON.
If the Computer keeps turning off automatically even when the AC adaptor is connected to it then the issue is with the power supply unit and requires to be replaced.
Oct 24, 2009 | Dell Computers & Internet
My computer turns on and off
Try moving it to another room and see what happens ,it could be interference.
also vacuum the air vents on the laptop.
It sounds like a hardware problem ,if it still has warranty then you should take it back
May 11, 2009 | Toshiba Satellite A205-S5804 Notebook
MY PC WONT COME ON THE SCREEN IS BLACK
The mother board has a battery if thats the one you took out you reset the bios, Try pressing the delete simutanuosanly after turning on the computer then in the bios goto boot device priority and select your hard drive press f10 which is the save and exit. Try turning on your pc again and see if it boots off the hard drive make sure you give the computer time to re-boot itself after you change the setting in the bios.
Apr 08, 2009 | eMachines T3604 PC Desktop
there is a problem in your power supply, you need to replace this with a new one
Jan 06, 2008 | Computers & Internet
Turn off by itself
Yes, you can buy new charger/batterys in PC World really cheaply and theres a Sale on now beacause its just after Cristmas so try there.
Dec 24, 2007 | Panasonic Toughbook CF-27 Notebook
Computer problem
i hope your dad is usin xp , type "msconfig" in run command a window appear click startup tab and selest all boxes now apply this restart your machine
Nov 25, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Coby mp3 doesnt turm on
Get a thin object like a needle or something and poke and turn in the small reset hole on the back bottom right.. SHOULD WORK FOR Mp3/Mp4 Coby 2GB PLAYER
Oct 26, 2007 | Coby MP-C7085 MP3 Player
Camera won't turn on
not sure if you have the same problem..but i have the same camera and when i turned it on the screen was all white..it still worked and took pictures but i could only see them on the computer.. i had my friends dad open it up and he found a foam like piece that fell from somewhere and was causing a wire to short out in the LCD screen.
Feb 16, 2007 | Samsung Digimax A503 Digital Camera
Toshiba Satellite 2060CDS Notebook Logo
1,138 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
