Question about JVC AV-48P775 48" HDTV
Hd signal not being picked up
My jvc 48" hdtv ready wont work wityh my comcast hd box. I have hd cable. I can see it through component wires but not through dvi wire. what can be causing this? do I need to set something on the tv or is it my cable?
  • 103 Answers
Your comcast box is not hdcp compliant.this signal tells the tv it isok to display the image.It is similar to video copy guard
Posted on Mar 06, 2007
Cable box connections
The model listed has only ONE HD input and it is on the rear and marked DTV--it is a component input with red, green, blue and a red and white for audio---cable box would have to have same outputs on its rear.
Apr 18, 2012 | Mitsubishi WS-48313 48" Rear Projection...
I have an older 2004 or so philips hdtv projection tv with the built in tv stand. i want to connect my HD cable box but there are no hdmi ports. and i buy a wire with the VGA on one end and hdmi on the...
Get a component video cable (blue, green, red) and a separate RCA audio cable (white and red) if your cable box has a component video output and the TV has a component video input.
If your cable box doesn't have the component output, you will need a converter to go from the HDMI to component video. Something like this: http://www.hdtvsupply.com/hdmi-to-component.html . There are other converters available if your TV has some other inputs available.
A cable that has an HDMI M on one end and a VGA M on the other will not work. HDMI signals from the set top box are a digital signal. The VGA port on the TV is set to read an RGB analog signal. (Similarly a component to VGA cable would not work since the RGB and PbPrY are not compatible.)
I hope this helps.
Sep 02, 2011 | Philips 60PP9363 60" Rear Projection...
I have a D52W20. I bought a HDMI cord thinking it was what I need, what is it that I DO need for HD?
To correctly get HD, you need to satisfy three things.
First you need an HD tv.
Second you need an HD signal. IE.. HD cable box, Blu Ray etc..
Last, you need either HDMI wires or Components wires.
Hook the HD box up to the TV with component wires(I believe you tv doesn't have hdmi connections), go to the correct input and enjoy.
Feb 20, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I get the HD on this model? Which cables/hook up should I use? I do not have a cable box or set top box but if these are required, please let me know. Thanks!
Your unit is HDTV ready but is not an HDTV. It is capable of displaying HDTV only through the component inputs. Your tuner is analog NTSC and will not receive HDTV or digital.
You could get an HDTV picture using a Blue Ray DVD and hooking up the component connectors from the DVD to the TV.
The only other way would be to get an HDTV tuner with a component output and hook it up the same way, component out to component in, and hook the tuner input to an off air antenna (receiving HDTV) or cable or satellite with HD signals.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 21, 2010 | Sony KP-51WS510 51" Rear Projection...
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Comcastt HD Box indicates "Component 3 - Not supported mode"
Try HDMI if the TV has the inputs or swap the component cable.
Jul 02, 2009 | Samsung HLN5065W 50" Rear Projection...
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
JVC AV-48P775 48" HDTV Logo
174 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
