Question about RCA F32649 32" TV
RCA Guideplus Gold Television
When you plug in my television it makes a popping or crcking noise. It will turn on , there is sound and somestimes there is a picture. It starts making the noise as soon as you plug it in.
  • 24 Answers
I would guess the popping/cracking goes away when the picture is present. Sounds like a high voltage arc either withing the tube or due to a cracked component in the high voltage circuit. If it's the tube, then the question is: how old is the set and is it worth it to sink $$$ into it as opposed to putting the same into another unit. If it is a defective component, that's much easier/cheaper to repair. Again, age of the set, etc. I hope this helps; definitly a repair for a pro.
Posted on Oct 30, 2006
RCA Guideplus gold gemstar analog or digital
Most of the RCA GuidePlus Gold gemstar TVs worked with analog TV signals (NTSC) only. The Guide+ information was only broadcast in NTSC signals and is no longer being provided. If you can check the date of manufacture of the TV, you can use the size to check if it had an ATSC tuner added if it was made for the US market. 37"+ TVs had to have a digital tuner in second half of 2005. 25" TVs needed to have the ATSC tuner after March, 2006. The next year all TVs had to have a digital tuner.
I hope this helps. Please add a comment with the model number of the TV, if you would like me to confirm the tuner information on your set.
(The RCA F31317 TV with Guide+ was manufactured in 2000 and thus only has a NTSC tuner.)
Dec 26, 2015 | RCA Televison & Video
What might be the problem with tv making popping noise when turned on
you must have a wire ( sound plug ) not connect properly ,
sometime those plug loose with time ,
when powered the make connection and those sound happen !
Apr 05, 2015 | RCA L32HD31 32 in. LCD HDTV
Popping sounds only during video/ you tube on tv from my computer.
Because of the amount of voltage required to run the older-style "tube" televisions, many problems, sounds and noises occur in tube televisions than in the newer, flat-panel televisions. Sounds occur for multiple reasons, with some being just part of the normal process these televisions run through in order to operate. On the other hand, some of these noises may indicate a problem with the television that could warrant repair.
Worn Insulation
Voltage against metal. Inside your television's tube, there are many wire parts that electricity runs through in order to make the television run. Usually, these parts are insulated with a rubber or foam casing that prevent the sound of the electricity. If the insulation surrounding these components is thin, weak, worn or absent, you are bound to hear buzzing, popping and cracking sounds coming from your television. While this may not mean you have to run out tomorrow and get a new one, the chances are that your TV's tube is working extra hard to make it all happen for you, and you may want to start pricing new sets for the near future. b> Static During Warm-Up b> Just like rubbing your feet on a thinly-carpeted floor can cause static electricity, the same can also build up inside your television. If the noise is relatively subtle, only occurring when you first turn it on, and not overly-disturbing, the chances are that the cracking and popping sounds you are hearing are just the television's way of warming up and getting rid of the unnecessary electricity. Bad Lamp b> Deep inside the heart of your tube television, there is a light-bulb fixture that makes the entire unit light up so that you can see a picture. If the cracking and popping sounds you are hearing tend to go along with the picture on the TV becoming unclear, it could be that the picture tube is failing. It is very difficult and costly to replace the picture tube on a tube TV, so this is an instance where you may benefit more from buying a new television than taking the old one in for repair. Hope this helps.
Dec 21, 2012 | Computers & Internet
I was just given a 36-inch RCA Gemstar Guideplus Gold TV. I do not have cable and am unable to tell if it is digital or not. I've been told it is less than 6 years old. It is a tube TV.
RCA made only two 36" televisions between 2004 - 2010 and neither one of them have digital (ATSC) tuners. They made ZERO CRT televisions before that with digital tuners.
Apr 23, 2011 | Televison & Video
I have a RCA Home Theatre, gemstar guideplus gold. I think it is a 52" rear projection. I just want to know is it a HD TV?
It does not have an HD or ATSC tuner. But it does have HD resolution inputs - ie HDMI and component video (RGB) so effectively it is HD
Nov 24, 2009 | RCA D52W19 52" Rear Projection Television
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
Have sound but no picture
the internal bulbs have deteriorated...the manufacturers are real smart, these monitors dont last forever. So if repair estimate is too expensive then replace the whole unit.
May 24, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
RCA F32649 32" TV Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
