Question about KitchenAid KEBS177 Electric Single Oven
Self Clean does not work
Self clean of Kitchen Aid KEBS177 oven does not work: Lever to lock door works and all functions look to be working except that the "lock" light does not come on. Timers work and clean cycle sets and engages but oven never heats. Thank you
  • mike999 Feb 09, 2008
    The self clean was on for a long time, seemed fine, and then blew a breaker. Since resetting the breaker, everything looks like it is working on the display, but there is no heat, top or bottom. Ideas?
  • rexprints Feb 10, 2009
    It's happened twice!
  • KitchenAid Master
  • 43,501 Answers
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Posted on Sep 30, 2010
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    Cant unlock oven door
    Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
    *Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
    Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
    Upper oven will not self clean. The door lock does not actuate when self clean is selected. All other functions seem to work OK
    heatman101
    Nov 23, 2010 | GE Profile JKP56 Electric Double Oven
    I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
    If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
    Mar 13, 2010 | Frigidaire 27 in. Electric Double...
    How do I get self clean to work on older fridgidare stove
    Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
    Jan 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
    or
    Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Gerangeoven door won't open
    Is it in time bake?
    Oct 04, 2009 | GE Ovens
    Amana oven
    Error F-9 means:Door lock safety circuit on ERC sensed Replace the door latch assembly
    To solve this...Just press and hold the door latch to unlock position and then press cancel for a few seconds. The latch will return to its original position
    This will probably fix it..but if doesnt work try this
    Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
    You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
    If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
    Oct 17, 2007 | Ovens
    KitchenAid KEBS177 Electric Single Oven Logo
    414 people viewed this question
    Top KitchenAid Ovens Experts
    Marvin
    Marvin
    Craig Butler
    Craig Butler
    Jim Goldsmith
    Jim Goldsmith
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
