-   WHEN I TURN ON THE TV AFTER 15-20 MIN THE LIGHT FLASHES THEN AFTER 5 MIN OR SO OF FLASHING THE SCREEN FLASHES BLACK 5 TIMES THEN STAYS BLACK ON ANTENNA AND VIDEO HELP!!!-   mjs1grl
Nov 19, 2007
-   WHEN I TURN ON THE TV AFTER ABOUT 15 -20 MIN THE LIL RED LIGHT KEEPS FLASHING THEN IT FLASHES A BLACK SCREEN ABOUT 5 TIMES THEN STAYS BLACK SOUND IS STILL THERE. HELP!!!-   Guest
I would try adjusting the screen control on the flyback. The flyback can be easly located, find the red wire attached to the top of the picture tube & follow it down to the flyback. on the flyback you should find two controls, one screen & one focus. you sould be able to read the words above each control, only adjust the screen one. slightly increase the control till the picture stays on, if you turn it too much you will get small white lines going across the screen. Now if what i have told you fixes the set, then it is only a tempoary repair. could last days or mothes, maybe years. if it starts to happen again later the set will have to be replaced. this is a sign of the picture tube starting to get a weak. ALSO DO NOT PLAY WITH THE RED WIRE IT CARRES VERY HIGH VOLTAGES EVEN WHAN UNPLUGGED FOR DAYS.
I have a Sony Wega Trinitron CRT 36" HDTV(KD-36XS955). I bought this 4-5 years back and all has...
(More)
I have a Sony Wega Trinitron CRT 36" HDTV(KD-36XS955). I bought this 4-5 years back and all has been fine. I have noticed recently that the screen looks like it's bowing down on the sides. It's especially visible when viewing something in widescreen format as you can see the black bars clearly bend downward on both sides. There are also 3 horizontal black lines that i think might be dead pixels? these lines are barely noticeable, but once you see them, they get annoying. any help would be appreciated.
Thanks,
Andrew
TV will not turn on, makes the initial noise like it is turning on, then can hear it click off, and...
(More)
TV will not turn on, makes the initial noise like it is turning on, then can hear it click off, and red light flashes several times
I have a 36 wega the picture comes on and goes out and stand blinks 6 times. sounds like power...
(More)
I have a 36 wega the picture comes on and goes out and stand blinks 6 times. sounds like power supply any suggestions Hi I have a similar problem with my 5 Year old Sony KD-36XS955 with black lines covering the bottom half of the picture where the top part of the picture is "prefect". The lines started 1 or 2 inches from the bottom and increased to 1/2 way after a couple of days. The stand-by light blinks twice and repeats after 5 seconds. Please help... Thx!
plug i smelt that smell like something burt ,since than i cannot get it to autoprogam channels but...
(More)
plug i smelt that smell like something burt ,since than i cannot get it to autoprogam channels but the kids can play games just fine and it will play movies from a dvd or whatever ,and letters and screen is still blue it just will not get reseption or progam channels
