How do I use the menu function on the remote. I can get the menu to pop up on the tv but I can't figure out how to navigate on it
SOURCE: i have lost the ge universal remote guide for the
These are the steps on how to program your GE Universal Remote Control without the list of codes.
1. Manually turn on the device to be
controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired device button. The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
Note: Code Search starts from the currently stored four digit number under that mode. Sometimes the
first code that “works” with your device may only
allow limited functionality (e.g. the MENU button
might not work). There may be a code that performs
more functions. Continue the code search process
until the best code is found.
5. Press and release ENTER to install the code.
SOURCE: I have a GE 24914 Universal Remote. I would like
Hi! These are the steps on how to program your Ge Universal Remote Control to your Emerson TV.
1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
2. Press and release the desired TV button. The red indicator blinks, then stays lit.
3. Enter the 4 digit code indicated below.
Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your TV on, press ON•OFF. If the TV turns off, no further programming is required. Note: If some buttons do not operate your TV, try one of the other
codes.
Codes for Emerson TV are 1172 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0210 0227 0233 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
SOURCE: I need GE 24914 Universal Remote Control codes for
Four digit code are
0053 0189 0227 0456 0024
Three digit codes
024, 033, 053, 189, 198, 227, 456
Three digit codes (purchased before August of 2002)
033, 038, 189
Thanx
