Question about Sony KP-46WT510 46" Rear Projection HDTV
Song KP-46WT510 I'm pretty sure that I have a problem with convergence at this time with this model. I really don't want to fork out a lot of money for a tech to come out and screw a new part in. Is this something that Ican fix and get the part for? Thanks for any help you have.
    Problem Solver:
Replace the two stk362560 and you are good to go
Posted on Sep 27, 2007
My sony tv model # KP-46WT510 the picture bows to the middle i tried fixing the convergence and it does nothing what else should i try
If the convergence feature did not fix the issue then you will need to install a convergence repair kit. Your model uses the Sony type 1 convergence repair kit which is available from www.tvrepairworld.com and includes the parts and the CD with instructions.
Aug 28, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Why has my hd lost its luster? not asclear, smoky picture. its a sony rear projectile tv hd 46in. model kp 46wt500
usually these tvs will need a tune up from time to time. You can try to push the flash focus button on the front and that will fix any minor misalignments, but to really fix it, it likely needs the crts focued and a convergence re-alignment. sonys are tricky, but if you feel savvy and want to dive in, let me know.
a tune up may run $50-150 from your local repair shop
Jun 14, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Replaced STK's, fuses ok, +/- 22 VDC ok, still can
did you checke the two 5amp IC protectors located on the G board? Those will usually blow when the original ICs fail.
Jun 12, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence problem
you need to replace the convergence ICs, pico fusses and possibly a couple of the feed resistors. you can get the kit for your model at the following link which contains the parts and instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Jan 28, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My sony wide screen projection model kp-46wt510 has a red shadow
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46wt510 Convergence issue
convergence ic's replace all 3 be carefull make sure to reapply the thermal compound to the heat sinks after cleaning the old stuff off stk's can be had from global
Oct 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
The red convergence is off
replace the convergence ICs post your model and I will post a link where you can get the parts and they include step by step instructions with pictures so you can do the repair yourself takes an hour and will save you about a 400 dollar repair bill.
Mar 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
