Question about Hitachi 50DX20B 50" Rear Projection Television
Not powering up
I have this Hitachi 50DX20B rear projection TV and it has worked perfectly until recently. Turned it off one night and the next morning it would not come on. Unplugged it for several hours and plugged back in and power light would come on for just about 1 second then back off - never turning tv on. Then it would not come back on unless I unplugged it for several hours again then it would do the same thing - just turning on the power light for about 1 second or so.
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
  • 1779 Answers
SOURCE: 57t600 wont power up
Both of these problems sound like the 2 convergence ic's. Not something the owner is really able to repair. You'll need to call a svc co.
Posted on Mar 20, 2008
  • 927 Answers
Good Day, you all;
The front panel light on Hitachi TV does not really tell you much. To see what the TV is doing or better said NOT doing is remove back from the set.
If you are not a technical type person, it would be better to consult an authorized service center, but if you are perform this; 1. Remove back
2. Observe led and notice which once light, there are as many as 9 LED's.
Now that will tell you what area of the TV's circuits are to be concerned about.
Let me know, Good Luck, big IRISH.
Posted on Aug 06, 2008
  • 418 Answers
SOURCE: Hitachi Projection power shutdown??
Possible convergence chip bad.--'3-D color vision'.
Posted on Apr 17, 2010
Testimonial: "Thanks a lot! I appreciate it."
SOURCE: i have a 1994 50ex8k hitachi rear projection tv that wont turn on
it has a built in safety. there's a problem with tv board
Posted on Sep 10, 2010
  • 3459 Answers
SOURCE: I have a Hitachi SBX Ultravision 50" rear
This is a very common problem on your Hitachi model and an easy DIY fix. You can get the correct parts and instructions for this exact fix on
Posted on Jan 22, 2011
0 characters
1 Points
How do i adjust the lenses in a hatachi model 50dx20b?
Lens are adjustable but if picture is 3d or colors like the photos it is not an adjustment.
Oct 24, 2012 | Hitachi 50DX20B 50" Rear Projection...
For the Hitachi model indicated here it is not possible and if worked would have some real issues anyway--this set was not designed for this type of connection.
Apr 30, 2012 | Hitachi 50DX20B 50" Rear Projection...
Hello, I have a 5 year old 47" projection tv that has worked perfectly until recently. It was running fine one night and I turned it off for the night. The next night when I turned it on, there were...
You have a bad convergence circuit. You will need to replace the convergence ICs minimum and could have a problem with the digital convergence box. I have a tip at which explains the problem, where to get the parts at the best price and how to complete the repair.
Thanks for using FixYa and for the great rating.
Oct 06, 2010 | Hitachi Projection Televisions
Hitachi Rear Projection TV - C4678FS - No Sound
i am having the same problem with my hitachi.. if you find anything out plz let me kno
May 09, 2010 | Hitachi Projection Televisions
How to replace power supply?
Toshiba model 57H93 worked perfectly last night. Turned off and went to bed. Turned on this morning, and nothing, it won't turn on. Checked all cords and cables, pushed reset button, and still won't turn on. What could cause this to happen?
Dec 14, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Tv wont power on
I had the same problem Replace the IC's and it should fix this
Dec 31, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 50dx10b
Try unplugging and plugging back up the power cord to reset it.
May 14, 2008 | Hitachi 50DX20B 50" Rear Projection...
Hitachi 50DX20B 50" Rear Projection Television Logo
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
