Lexmark networked printeris is no longer accessible via our network
SOURCE: Lexmark Networking Problem
YOU CAN INSERT AN OPTIONAL NETWORK CARD ON YOUR OPTIONAL SLOT THIS SOLUTION IS OK TO USE NETWORK WITH THE PRINTER; THE CONNECTION BETWEEN THE ONBOARD NETWORK CARD AND CPU IS BROKEN AND THE SOLUTION FOR USE THE ONBOARD NETWORK IS TO CHANGE THE MAIN BOARD;
SOURCE: Lexmark X1185 Not working with Vista
You might try downloading the Vista driver for your printer onto all of the computers on the network that have Vista...
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:435:0:0
Hope this helps
SOURCE: lexmark 540n 976:0 service network software
Had the same probelm. Resolved it by disabling AutoIP feature in Network Settings. Also set hard IP without DHCP.
SOURCE: Hello, I got an Lexmark
A 900.80 error indicates a problem with the current print job or with a part within the scanner unit of the printer. Please click on the link below to see instructions on how to go about the procedure.
For further assistance, please call Lexmark Technical Support.
