Question about RCA P61940 61" Rear Projection Television
RCA 61 inch TV No sound / No picture just a little noise when i hit the power button. help ?
I have a 7 year old 61 inch RCA projector TV model p60928 The repair man said it needs a power suppply or HV componts . For them to reapir it the charge is over 400.00 I would like to know if i can buy the parts myself, Where do i get them and a manual ? It's not worth me spending 400.00 but i have a friend that'll help me fix it if i can get the parts. right now i have no picture and no sound only a little click when i hit the power button. Thanks Lisa
MikeNJ1964
  • 398 Answers
SOURCE: rca 60'' p60928
The set does not have a blue lamp. The set has a blue picture tube. I have found that the best RCA parts distributor is Union Electronics at 1-800-648-6657. The picture tubes in projection sets are very fragile and dangerous to handle. The new picture tube will come dry, so the lens assembly and seal will have to be assembled onto the new tube and then filled with fresh coolant. The set will then need a complete realignment, everything from screen and focus voltages, bias and drive, yoke and ring position to convergence circuits. If you have no experience in any of the above, do not attempt to replace a picture tube. Allow a qualified tech to handle it for you.
Posted on Aug 28, 2007
SOURCE: Screen went black, no picture
Where us the r4703 resistor located at is there a schematic for it somewhere i can see?
Posted on Jun 30, 2008
SOURCE: RCA DLP TV needs color wheel replaced
I used the internet and found others who had the same problem. Two individuals had a brief description on how to replace the color wheel in a DLP TV. Three small torque screws and a ribbon connector was all that was need for removal; once the access panel on the back was opened. I would guess that this process is the same for all DLP TV's, with some small variations!
Posted on Nov 30, 2008
  • 178 Answers
SOURCE: rca 61
he is right to an extent however if you want it fixed it will cost you but the engineer should have been a little more polite about the matter
Posted on Sep 24, 2009
SD Tech
  • 14553 Answers
SOURCE: Have an RCA 60
It is the 169 chassis-over 300 different models used it and are different-answer something for me--does it have a GREEN power light that comes on for a second and goes off?
I know this set well and to be honest hated working on them--Let me know about the power light and I will tell you what I know.
At one point in time this was a very good set--I do understand about paying a lot to get it fixed and having it bad again.
I am here to help people and I bet I know more about this set than almost anyone else here.
SD TECH
Posted on Dec 15, 2009
I have an rca 61" dlp tv that is about 4 years
More than likely you have a power board that is failing. Since the TV is so old I doubt it is under warranty still. I estimate it would cost you anywhere between $300-400 to repair that problem so it may be time to switch to a newer LCD TV.
Feb 28, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Picture on 36 inch toshiba tv out
I had the same problem on my 61" RCA TV... The switch for the power/channel changing buttons seems to be a faulty product... However if you are a little technical you can open up the front of the TV and disconnect the button panel from the tv and just use the remote to operate it.
Jul 02, 2009 | Toshiba Televison & Video
Tv repair
Hi; i have a 36 inched color television and it has a horizontal line going arcross the TV ,but it sounds like it is on but do not show a picture.Zenith Model# Sy3572DT and Serail# 781-4171582 I would like to purchase a part to replaced
the old one could you help me.......
Thanks
May 31, 2009 | RCA P61927 61" Rear Projection Television
Rca 61 inch not working properly
The vertical heigth is too high. whats the model number of your set?
Jun 12, 2008 | RCA D61W20 61" Rear Projection Television
Rca 61 inch projection tv model D61W20
Steve,
I have the exact same problem with my tv. same model. If you happen to find a solution, could you please forward it to me. I will be very appreciative. email me at jjkjjk13@hotmail.com . I'll do the same for you if I find a solution.
Jan 20, 2008 | RCA D61W20 61" Rear Projection Television
My rca p60752eblg2
Yes it does sound like the flyback is bad, the only other thing that arc is a picture tube.
Dec 05, 2007 | RCA P61940 61" Rear Projection Television
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
RCA P61940 61" Rear Projection Television Logo
407 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
