Question about RCA CC4393 VHS Analog Camcorder
TAPE MECHANISM WON'T ROLL THE TAPE, IN EITHER RECORD OR PLAYBACK
  • 45 Answers
Problem with the tape transport mechanism; could be the rollers are not contacting the tape itself or it could be the springs in the transport. Sounds like an older model. Could clean the rollers with alcohol and swap and if you can open it a like observe what happens with the rollers when you place in playback. These are rather delicately adjusted machines. I would again 1) try cleaning as best you can and very light oil in moving joints/gears aferward. 2) check adjustment of springs when moving from stop to playback. Once you have that whipped the record mecanism may start working as well.
Posted on Apr 02, 2012
SOURCE:
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
Minutes left on tape not displaying
Is it when you do playback on tape or when you do a recording
Dec 09, 2011 | Sony Video Cameras
Static on playback
When's the last time you cleaned the recorder?
Nov 11, 2011 | Maxell GX-MP120 (4 pack) 8mm Tape
I have a NV-DX110B about 11 years old. I'm getting
Your camera appears slightly older than mine so I will do my best for you. Have you tried ejecting the tape with the power off? If I have problems I slide the eject button when the camera is off but plugged in and the tape can be ejected. I suspect the tape mechanism is in trouble. When a tape stuck in mine I had to literally force the cover open. But this is a last resort.
Give my suggestion a try and apologies if you have already tried that...
Sep 11, 2011 | Panasonic Video Cameras
Picture Rolls Vertically during VHS playback on EWC19T3?
Hello
If the fault is only with tape play, and not with on air programmes, it is surely either with the tape or with the mechanism. Look at the tape filim for any curl at its bottom edge. If there is curling, rolling will occur becuse, contol signals are recorded at the botton edge of the tape. If top edge hage curling, sound will be effected. If there is no such mistake with tape, the pintch rollar of the VCR mechanism has worn out, and should be replaced. OK.
Jun 30, 2011 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
MY AMP SU-Z600 AS RCA JACKS tape rec out extplayback & the EQ has tape rec out /playback how do they interconnect
Simply stated: TheEQoes onto a Tape Loop of the receiver. Outs to Ins but keeping in mind the EQ's own Tape Out's and In's are for any tape recorder attached to IT. Loops withn loops.
Apr 14, 2011 | Technics Audio Players & Recorders
Have a reel to reel tape recorder that has a bad Hum in playback mode. What could cause that?
Most hum is caused by a faulty electrolytic capacitors. If the hum is accross both channels, then it's most likely one in the power supply part. Maybe the big one that filters the 50/60hz mains hum. The reason you will hear it in playback, is that a switch will be opened up when the mechanism goes into play. This switch connects the tapes pre-amp to the audio out circuit.
Jul 10, 2010 | Audio Players & Recorders
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
VCR recording
As with all tape related recording equiptment, the path the tape follows in your machine will collect debris which will interfere with the synchronizing playback signals originally recorded on our tape when first recorded. The "ROLLING" is the loss of those synchronizing signals and the "skewing" of the tape where the heads are now reading between the recorded information causing noise at the top or bottom or throughout the entire screen. SOLUTION for about 85% of machines exhibiting this problem is CLEANING and inspection of tape path alignment best done with a calibrated playback tape for accuracy. HOPE this helps . . . Jaszy
May 29, 2007 | Maxell 10 Pack T60 Blank VHS Tape PI PLUS...
RCA CC4393 VHS Analog Camcorder Logo
109 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
