Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony WEGA 36" Trinitron HD
Hello. My TV has a 1/2" black border on all 4 sides. I have attempted all the different setting functions on both my Sony and DirecTV remotes. Tried resetting the dish with no luck. Hoping this is not a issue with the TV tube inself. Any ideas? Thanks for the help.
U have a problem with your power supply circuits. ur regulator circuit is not function well thats why ur picture is a little bit smaller
Posted on Jan 15, 2007
  • 97 Answers
Check for unit posting any blink codes on the timer LED. Google "sony blinking codes" for the explanation. Try turning unit off for 4 hours to force a hard reset of your set, you need to unplug it. Sounds like a low voltage problem in the HV circuit.
Posted on Jan 14, 2007
  • Kris Wingert Mar 28, 2007
    The flyback transformer is not outputting 32+KV to the anode. This is a low voltage problem that requires trranformer/supply repair.
Sony Wega Trinitron TV image has shrunk?
Check its main power regulator section circuit for any loose solder terminals. Low power regulator voltage output is the problem to your TV.
Nov 19, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv screen shrunk in from the sides
Ok, you have a problem in the Horizontal output circuit--width etc.
Going to be a shop repair as most shops will not tackle this in the home--36 inch from the model indicated so expect repair to exceed 150 parts and labor.
If the border is not large on both sides the set also has a tech menu accessed with the remote--adjustments are there for centering and width--it will not fix a circuit problem.
May 03, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
How to hook up an HP dv7 laptop to a SONY Hi-Scan Trinitron (not HDMI)?
U can't,not an HD tv,only HD tv have design for computer connections.
Nov 10, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony 36 inch trinitron no picture no sound
i cannot get a signal from my HD cable box to my Sony Wega KDF-E50A10 TV's thru the HDMI cable.
Jun 20, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Want to know if my soney wega trinitron is hd compatible
is hd compatible but your hd will have black bars on top and bottom and shrink your tv to about 19"
Jun 02, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Video 4 not working properly
9 out of 10 times, the problem is the device that is hooked up to the TV, and not the TV itself. This is especially true in the case of cable boxes, which have a long history of failures.
Temporarily, you can probably hook up the composite (yellow red and white) cables to get a picture and sound on a different input.
You can try to hook up a DVD player on the inputs (component, I'm guessing) and it will probably work. Then you get to call the cable company!
Hope this helps...
Jan 09, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
KV-36XBR450, FD Trinitron WEGA
Hello maymet,
This sounds like the HV protection circuit is cutting off the TV due to a high current event in the set. This could be a problem in the High Voltage section of your TV (Horizontal output transistor, Integrated High Voltage Transformer, and y of the deflection components, and or the CRT in cases of shorts).
I would suggest that if you do not have a background in electronics, you should have an experienced TV technician troubleshoot and repair this problem.
This is due to the nature of the dangerous voltages that are present in the television.
I hope this helps,
Thank you,
Shuttle83
Nov 02, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron KV-36HS20
I have this set also..
When you set up for an HD signal (1080i) it is broadcast in 16:9 which is a widescreen format. The Sony set is a 4:3 format (more of a square shape) which means the black bars at the top and bottom appear so that you get the widescreen 16:9 format to appear.
This is one of the main negatives I have about this set, however, I can't really complain as I have had it for 6 years and it works great.
I never knew about the other format until I got an HD receiver from my satellite dish provider last year.
Hope that helps explain it for you..
Jan 25, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
218 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
