SOURCE: I have a Singe 3116. The needle not working
the clutch is out. that allows you to wind a bobbin. take it out of bobbin mode and put it in sew mode (clutch in)
SOURCE: my machine's motor is working but the entire
Have you disengaged the bobbin winding features?
Testimonial: "Thank you so much for your help! I got my sewing machine working again. great online help for this kind of technical problems. "
SOURCE: motor stop working. the hand wheel works to sew
Check your bobbin winder lever, make sure that it is fully disengaged.
SOURCE: I bought a used Bernina
Let me say that is a fine sewing machine. I have the fix for your issue. Your sewing machine has an electronic system that takes the needle to it's highest point when ever you take your foot off the pedal, the front side of the pedal. If you tap the back of your pedal with your heel the electronic system will take the needle down into your work. If you again tap the back of the pedal again with your heel the needle will go up. In short the front side of the pedal is for full speed sewing where the needle can stop in the full up position at anytime. If you want more direct control of your needle then simply use your heel on the back of the pedal.
Regards,
Tony
SOURCE: I just bought a used
If you go to your local jo-ann's or hancock, they generally have a technition who comes in once a week our so to fix machines. A tune-up will generally run between $60-100, and thay should help your above mentioned problem, as well as keep everything else in tio-top shape. If there were, by slim chance, to be any additional costs associated with such a repair, the repair person will tell you ahead of time. Congrats on your new purchase!
