Hitachi 50UX58B 50 in. Rear Projection Television
Problem for Hitachi 50UX58B 50 in. Rear Projection Television
Green lights
By jd5449 on Oct 29, 2006
the green lights on the def pwb come on and then go out but if i disconnect the psd3 jumper from the signal board all the lights come on but the green for the tv on the def board can i just take board out and replace or is it repairable
Comments:
Nov 12, 2006
- I replaced c707 and e994
Nov 02, 2008
- The tv was repaired by replacing c707 and e994
Best Solution
posted on Nov 02, 2008
Helpful)
save85
Rank: Apprentice
Rating: 85%, 1 votes
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Was this helpful?
Yes
No
Solution #2
posted on Aug 18, 2008
Helpful)
ahhsoo69
Rank: Wiz
Rating: 84%, 87 votes
HELLO I WOULD REPLACE THE HOLE BOARD.!!! AND GO FROM THERE. HOPE THIS HELP'S YOU.!!! "GOOD LUCK"
Was this helpful?
Yes
No
Popular Solutions for Hitachi 50UX58B 50 in. Rear
Questions and Unsolved Problems for Hitachi 50UX58B 50 in. Rear
Do you recommend Hitachi 50UX58B 50 in. Rear Projection Television?
Answer
Answer
wwood51375 yes those components can also affect the color. I tried answering your question but they... (More)
Answer
screen has a double image. looks like the green gun is bowed at the top and bottem of the screen.... (More)
Answer
50ux58b had lost poewr, red light went out never came back on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
