Question about Mitsubishi WT-46807 46" Rear Projection Television
Burnout ? wt-46807
Replaced the TIVO and the wt was working fine. Left the room, returned 20 minutes later and the screen was black with perfect sound. Tried changing the inputs with remote as well as from in front of TV. Was unable to open the home/ guide/ menu. Have only black screen. IS this fixable? naturally the five year warrantly expired last month! THE CABLE CONNEection was reattached to another tv and the "new" tv works fine. So, is the WT-46807 a lost cause? What do you/can you estimate what potential fees for repair? I am quite handy but do not think that I want to tackle this problem. I also dont want to be ripped off from a service company as well. A new set is expensive but for 350-600 dollars I think it would be worth fixing. Thanks for a rapid reply. Would like to get fixed ASAP Thank you Jon B
  • Anonymous Dec 29, 2007
    Currently this TV is only being used with the Antenna B input for standard cable and for video games via the component 1 inputs. The xbox 360 games work fine through the component 1 inputs but through the antenna B input I have audio but no video. I've tried switching the cable to Antenna A with no luck. Any ideas?
    President:
  • 3,130 Answers
There could be a Pip problem or the vertical sweep could have went out also so then the set shuts down the video so it does not burn a line across the tubes. Theres really no way to tell what is wrong or it would just be a guess, a shot in the dark. Call out an authorized repair depot and get an estimate. Good Luck
Posted on Oct 30, 2006
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
TV was working fine untl I accidentally hit the Menu button, then the screen went black except for the top bar that shows the channel, program name, description, etc...
Press the TIVO button. This should return you to the main screen. If this doesn't work, the box is most likely hung up. Unpolug the power cord, count to 10 and plug it back in. It will take a few minutes to boot back up, but this should fix the problem.
Jul 17, 2013 | Tivo Series 2 80-Hours Video Recorder
3 horizontal lines on Samsung LN46A650 upon start up. Causes the Tivo menus and on screen graphics to refract. Goes away within a 1/2 hour but returns when powered down and restarted.
I had the power board capacitors on my Samsung 46LNA650 checked, and the out-of spec/leaking ones (13 in all) replaced. The horizontal lines disappeared; but, the left side of the panel was dark for about 20 minutes (until warmed-up). I then found this forum/link that solved the problem! This simple fix was probably all that was ever needed - IT WORKS!!!!!!
http://forums.cnet.com/7723-13973_102-391250.html
My Samsung now has a perfect picture again.
Nov 16, 2010 | Samsung LN46A650 46 in. LCD HDTV
I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
TIVO is stuck on start up on a sony svr-3000
It sounds like you need a new hard drive. I'd recommend you visit this TiVo repair website.
Sep 04, 2009 | Sony SVR-3000 TiVo
NO PICTURE OR SOUND
It seem that the OSD still working but the screen is black. try to resolder it first because many old tv has cold solder problems.
May 31, 2009 | Apex Digital AT2008 20" TV
Mitsubishi WT-46807 46 in picture bends and the blue red and white all seperates
intermittent convergence fail. suggest re-soldering the 2 convergence output ICs on the middle power board. they are the 2 large devices located on the largest heat-sink on the middle board(looking at from back) once you re-solder them as long as the aren't faulty internally you should be all set.
Mar 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Black Screen When Open, but the Picture quality is fine
in the lower right hand corner there is a button that has disp. on it just click that during picture taking mode and it will return to normal
Dec 25, 2006 | Canon PowerShot SD600 Digital Camera
Mitsubishi WT-46807 46" Rear Projection Television Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
