Question about Kenmore 45981 Washer
Error code F11 and orthers
Where can i find what the error codes mean. I can not find my book and need to know what they mean before I call repairman. F 11 is one that keeps popping up every cycle. It just stops and beeps. I can restart the washer but then it beeps and stops again.
  • luxordevco May 11, 2010
    I have the same issue - replaced door lock- control panel and module (but put back old module) - ran thru test- says OK- but not- what could it be?
    President:
  • 878 Answers
Gailo, F11 is a serial communication error. Communication between the central control unit and the motor control unit cannot be sent correctly. Possible solutions: Check the harness between the two boards for loose connection. Driver motor, main board or motor control board may be bad. I have come across a number of these with loose connections and bad main boards. Put it into a test by pressing drain/spin on the left side. Then press the spin speed button on the right until no spin is lit. Then press the pre-wash button on the right 4 times until 00 comes up in the display. You are now in the automatic test mode. Let it do it's thing about 15 minutes and see if the error comes again. Catriver...post back.
Posted on Oct 29, 2006
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    F11 error code
    I appreciate the post, dan moore!
    From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
    Dec 14, 2014 | Frigidaire Kitchen Ranges
    Kenmore gas range F11 error code
    The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
    Dec 13, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    Error code f11
    I do not know what the error code f11 means on your appliance but I do know that if you cannot find it in your manual you will obtain the information you require from the manufacturer or a reputable dealer or service engineer. If this error code relates to an open door and you are satisfied the door is properly closed then the switch that closes the circuit that permits your oven to operate is not operating. This may be due to the oven door seal stiffness being just enough to keep the switch contacts apart or it may be due to dirt or grease preventing a clean electrical contact being made.
    Jan 17, 2012 | Tappan 30IN ELEC IGNa Oven
    Washer is flashing F and H
    F11 and FH are two completely different error codes. "F11" is a Serial Communications error between the Central Control Unit (CCU), the Motor Control Unit (MCU) and/or door latch. The "FH" error is a No Water Detect error code that means the CCU is not detecting ANY water or INSUFFICIENT water during the fill cycle. The following two links explain each error code and some things to look for to diagnose your problem:
    "F11" Error:
    http://www.fixya.com/support/r3608695-f11_error_code
    "FH" Error:
    http://www.fixya.com/support/r3608753-fh_error_code
    Read through the information provided and let me know if you have any questions. I hope this helps you.
    NOTE: There is a technical data sheet inside the washer that explains all diagnostics procedures, troubleshooting tips, error code explanations and wiring diagrams. To access, remove the lower toe panel under the door by locating and removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off. You can prop the two front feet of the washer up for better access to the panel screws (a 2x4 works well for this). The tech sheet should be located directly behind the panel, or affixed to one of the cabinet interior walls. I hope this information is helpful.
    Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I have the F11 and dL code. There is water and
    Hi
    Error F11 means Serial Communication Error i.e. communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. You need to:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Error code dl is a Door Lock Error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error. You need to check:
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Jul 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    F11
    these error codes are not specific FDL can mean door latch failure .it can also mean the ccu board has failed also F11 can mean mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor. if you do not know how to diagnose with out error code you may end up buying wrong part. sometimes doorlatch is not problem central control board CCU is
    Feb 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Sears He4 has a code F11
    Here is what the code means.
    F/11 Serial Communication Error
    Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    • Check MCU
    • Check CCU
    • Check Motor
    Good luck and Please Rate FixYa!
    Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Hotpoint wt741 f11 what does this mean
    Hotpoint Error Codes.
    Hotpoint washing machines are among the most common found in the Uk and like any mechanical device they will occasionally breakdown or develop a fault and need repairs.
    Being a very popular make means that most parts supplier will keep there parts in stock and because so many suppliers keep Hotpoint parts stock this also drives competition hence driving down the price of parts if you should ever need them
    One problem many people including some engineers face when faced with a faulty Hotpoint washer is knowing what the error code mean, so here are a list of error codes and there meanings for Hotpoint washing machines
    These error codes can some times have a E in front of the number and not a F as shown here, but the meaning of the code is still the same
    # F11 - This means there is No hot fill.The ambient temperature is probably below freezing perhaps due to the plumbing becoming frozen. Also verify that the taps are on or if the drain hoses are kinked.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Dec 26, 2008 | Washing Machines
    Could you tell me what F11 code means?
    F11 error code means there is a problem with the Control panel. Could be melted wiring, etc, since you left the oven standing. However, you can try unplugging the device from the power socket for about 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
    Oct 13, 2008 | Frigidaire Kitchen Ranges
    Kenmore 45981 Washer Logo
    226 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
