Question about Samsung Televison & Video
My samsung cr32z30 32" hdtv turns off automatically after running for about 30min to an hour. also the picture is curved on both sides when watching tv in 4:3 ratio. the curve is most prodominate at the top curving inward, with slight curvature on the bottom. also when the video source turns bright, the picture trys to readjust itself in size.
Linearity coil (there are several) shorted causing HV to increase and causing HVSD, no replacement parts available. Replace sweep module to fix.
Posted on Apr 07, 2009
  • ron347m Jun 26, 2011
    For the auto shut off, check the B+ voltage, it should be 145V. If it is higher (mine was 162V) then R818 (140k) has increased in value. That resistor has 140V across it and is part of the 145V supply feedback. The 145V feedback is a simple divider to a TL431 and opto-coupler.
Samsung HCL4715w Hdtv convergence issue
Maybe you can fix it in the service menu.
Turn off TV, press mute then 182, Turn on TV and check out new menu items
Jan 24, 2013 | Samsung HCL4715W 47" Rear Projection...
MY Samsung when you turn it on it have red line going down the side
A bad connection (solder) or a loose plug or cable someplace---problem with this set is the issue could be inside the front screen or Display Panel as it is called where it cannot be got at--replacing the Display is not cost effective if it is the cause as it costs more than a new set.
Dec 10, 2012 | Samsung LN40B530 40 in. LCD HDTV
I hit the remote on button the 52"samsung tv
Tries tv unplug,replug it back like about an hour later.For the tv to resetting itself back to the factory setting,it should be working again.If it is still have the same problems,the causes mostly the power supply board have the problems,that the board where the power a/c cord plug into it.Tries websites like a Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
Mar 21, 2011 | Samsung Touch of Color LN52A650 52 in. LCD...
Samsung LN40B530 40" 1080p LCD HDTV Picture rotated
how to rotate my samsung flat screen monitor turning up side down
Sep 08, 2009 | Samsung LN40B530 40 in. LCD HDTV
32in Westinghouse lcd / picture scrambled
my westinghouse has the exact same problem....i have noticed it will catch sometimes when the screen changes from one picture to another that is totally different and one right after another......
Jun 30, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Television picture does not work when first turned on
It seems that there are capacitors in the power supply which have dried or leaked, It is vurtually impossible to diagnose sight unseen however, the fact that it effected the three colours I envisage that problem to be associated with the supply, also the curving effect makes me look there, it seems that there is a ripple in the AC. I am assuming that it would take around 1.5hrs and cost of caps. This is working on the assumption that the fault is what I have listed without looking at it. Cost may be around the $150-$250 but don't quote me, I can't see the fault so it is an educated guess only...Phil
May 18, 2009 | RCA R52WM24 52" HDTV Projection Television
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Samsung HDTV top of screen is turning inwards
Mine is Same, Just got it back from repair shop. Two Convergence Chips Replaced. $220.00 Got it home and picture was perfect, after about 1/2 hour I now have the Line back and top curving. I suspect bad soldering
Nov 14, 2007 | Samsung HCM5525W 55" Rear Projection...
Convergence issue resolved but concave picture remains
Set will need new convergence IC's.Requires chassis pull===technical & mechanical skill mandatory.After repair,re-aligment necessary.
Sep 26, 2007 | Philips 55PW9363 55" Rear Projection...
Televison & Video Logo
872 people viewed this question
Jerry Greenberg
Jerry Greenberg
