Question about Sony Playstation 3 (PS3) Console
PS3 freezes 2 seconds after i cut it on
I cut my PS3 on and it freezes 2-3 seconds later, i tried cleaning it with a can of air and that didnt work...HELP!?!?!
  • smoggie1992 Nov 10, 2008
    freezes either on game or on ps3 menu, no matter what your on it freezes sometime a second after turning on sometimes 2 minutes either way help!!
  • 37 Answers
Sounds like there is a problem with your internal fan. It is most likely not able to cool down if the fan isn't working right so it is overheating and shutting off. You need to take it to SONY to have it looked at.
Posted on Nov 10, 2008
Ps3 froze installing system update
Cut it off. This should not mess up your HDD. Then i would just try again.
Dec 01, 2011 | Sony Playstation 3 (PS3) Console
My ps3 gets hot very fast and it been doing this from the frist day i got it i want to know if this is a problem
How to fix your PS3 when it's frozen at start up
things you'll need:
* PS3
* TV
* Game Controller
* USB cord
Instructions
The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
Put your PS3 in Standby Mode.
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
Time to enter Safe Mode.
Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
Connect controller to PS3 screen.
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
Safe Mode options screen.
Select option number 3, (Restore File System). Then select yes to perform step.
"The hard disk's file system is corrupt and will be restored."
First press the PS button to turn the controller back on. Then press the x button and it will restore, it will then restart and your problem is fixed!
Top multimedia features are on the console of PS3 and it is also connected with PlayStation Portable. While having all the high features, PS3 is not protected from occasional freezes and one knows that. It is the most irritating time when one is enjoying the best of the gaming time when everything suddenly comes to a halt. It is rare that PS3 will freeze but they do occur sometimes and are caused by scratched console disk or overheating.
1. Overheating: When the console is kept in a stuffed room where there is not ample breathing space, then it will get overheated and too much heat on the PS3 will cause a meltdown. It can easily be remedied when the console is placed all by itself and no other electronic machine is nearby.
2. Scratches: Scratches on the disk that can cause looping inside and this usually happens at millisecond speed. The console is not actually frozen in this case. Its the time lag that gets continuously repeated at certain times. The freezing of PS3 is generally not too serious. In case of worst freezing, the console has to be taken to the Sony store from where it was brought. The fact is that the owner can only do some basic trouble-shooting for fixing the problem.
If a PS3 freezes, it has to be kept away from other electronic machines at home. Its power button has to be pushed until a beep is heard. The loose cables have to be checked and they can be pulled and plugged back in. The hard drive has to be aired out for a while and placed back in the console after a considerable time.
If this does not help then the repair guide can be consulted to try fixing the PlayStation 3. It is completely detailed and illustrated.
Briefly, this is how it is done:
- The console has to be taken apart carefully
- The CPU and GPU of the console have to be checked. A white can be seen that may be cracked and unevenly spread, it will need a cleaning.
- The console's GPU and CPU has to be cleaned using a dry paper, if a sand paper is to be used then an extremely rough one should not be used.
- The flat surface has to be cleaned and if still there is a need, Arctic Silver 5 Compound can be purchased and used. It has to be applied evenly and thinly on both surfaces.
- The surface which distributed thinly makes sure that every single gap is covered.
- The heat sink cap can be finally put back on.
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
Why is it my mag freeze and ps3 ? i could move or play but could not actual kill as if i am not part of the game anymore any fix on this?
things you'll need:
* PS3
* TV
* Game Controller
* USB cord
Instructions
Aug 18, 2011 | MAG - PS3 for PlayStation 3
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Release the power button
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
Ps3 Freezes
Turn off the switch at the back of your ps3.
Turn it back on.
hold down the power button for about 5 seconds until the ps3 will turn on and then off automatically.
let go and then press and hold the power button again. it will beep once, then twice. Once it beeps twice let the button go.
ps3 will show a new menu. Choose option 3 to restore file system. Your ps3 might do the restore twice in a row and then it will work. None of your files will be deleted.
Jan 10, 2010 | Sony Playstation 3 (PS3) Console
Madden NFL 10 ps3 problems
when i try to go online to play a "friend" from my friends list, i get booted
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is freezing
Hey.
I might sound like a stupid solution, but if the PS3 is in a dusty area it sometimes freezes.. Try to vacume clean it.. Also, is your fan on and does it sound ok. It might freeze due to overheating. If it only freezes when you play games on a disc, it might be a problem with the laser reader, which could also be due to dust.
Hope some of it helped.
Regards
Jun 05, 2009 | Sony Playstation 3 (PS3) Console
Playstation won't stay turned on
THEY SYSTEM SOUNDS AS IF THE HDD FAILED THE 60GIG VERSION DOES THIS ALOT CONTACT SONY AT 1800-345-7669
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
Hanged
I read another entry and you have to hold down the red and green button and click your stylus into the bottom little button beside where you plug your phone in to charge.
It didn't fix my problem though which is similar to yours.
Sep 21, 2008 | HTC Touch P3450 Smartphone
Hanging
freezedMy HTC was working great!!...sudenly started to freeze and after that just turned off...I try to soft reset it....but it is still hanged how can i hard reset ?it worked at the begining(just for 2 seconds) but later the phone didnt start....and then it didnt continue the starting..sometimes after that just a clear white screen appeared. it freezed again.touch screen not working at all.
Sep 20, 2008 | HTC Touch P3450 Smartphone
Sony Playstation 3 (PS3) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
