Question about Whirlpool GEW9200L Electric Dryer
Dryer turns off in 10 minutes.
My Whirlpool dryer runs for 10 minutes and turns off. I don't think it is sensing west laundry.
    Scholar:
  • 66 Answers
To check the moisture sensors. Make sure the dyer is plugged in and all controls are set to off. Next to get into the diagnostic mode press more time, less time, more time, less time, all within 5 seconds. Now all indecator lights on the console are lit up with 88 in the " time remaining" display, if the test mode has been entered. Now this how to check the moisture sensors. Open the dryer door. You may hear a beep sound and the software revision number will be displayed on the console. If this happens there is a short in the moisture sensor system and the moisture sensors need to be checked and probably replaced. If this doesn`t happen,locate the moisture sensors on the face of the lintscreen housing and lay a wet cloth or towell across them. You should hear a beep and the software number will be diplayed on the console. If this happens then the moisture sensors have past the test and your problem is even deaper into the electronics and may reqiure a technician to trace this problem down.I hope this has helped you.
Posted on Nov 12, 2008
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
My dryer a Whirlpool. will run for about 10 to 20 minutes, then cuts off. After about 10 to 20 minutes, I can start the dryer again (push start button) and it will run for another 10-20 minutes. ....This...
there is a hi and a low tempreture sensor best to check those for continuity first when the dryer heats up and gets to hot the hi will turn off the heater where as when the low gets to cool it will turn it back on
hope this helps
Apr 30, 2010 | Whirlpool LER4634J Electric Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Dryer will not start cycle
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Feb 18, 2010 | Whirlpool GEW9250 Electric Dryer
Another Whirlpool Cabrio Sensing issue
Mar 29, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
No heat after a minute of drying
Your GAS dryer has no element.
You should remove the vent from the rear of the dryer.
Run on hi heat with no laundry.
Your exhaust temperature should be from 130 to 165 degrees.
If not you have a thermostat problem or a ignitor/gas valve problem.
Feb 21, 2009 | Whirlpool LGR3624JQ Gas Dryer
Whrilpool gas dryer
DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER AND TRY DRYING ONE LOAD OF LAUNDRY. IF THE DRYER WORKS O.K. WITH THE EXHAUST DISCONNECTED, YOU HAVE A RESTRICTION IN THE EXHAUST DUCT SOMEWHERE.
Apr 22, 2008 | Dryers
Whirlpool GEW9200L Electric Dryer Logo
497 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
