Question about Pentax Optio S30 Digital Camera
Fall My Pentax S30 fell on the floor while inside its case. The pictures are now 'washed' (white). Is it reasonable or is it simply an inferior brad/model or just bad luck? Any suggestions? thanks!
  • 641 Answers
Most of digital cameras are sensitive to falls especially on a stiff surface. You just have a bad luck.
Posted on Jul 29, 2007
Monitor shows white out screen
You can try firmaware update (below link) if available for your model.
But the reason could be also the LCD screen connector inside the camera. So it may need service.
Sep 01, 2013 | Pentax Cameras
32" TV fell over onto carpeted floor and won't
It's probably a write-off. The circuit board inside has been cracked so that some of the copper traces that connect parts have broken. This commonly happens around the area of the horizontal output transformer, which is heavy. The shock of the fall causes the transformer to bounce and breaks the board. Other areas too may have been damaged because of flexing. And worst, the picture tube can be damaged in a fall, so it either doesn't work at all or shows permanently distorted colors.
It's tough to find anyone willing to repair a set that's fallen. Many circuit board tracks are very narrow and hard to repair. Then it's difficult to know if all the damage has been found and repaired, so even if the set starts working a technician doesn't know if something else won't go wrong. And then there's that bad tube possibility; no technician likes to spend lots of time fixing a broken board only to find the set then needs a new tube. Trust me, this has happened to me several times during my career in TV shops.
Your best bet is to use this as an excuse to buy a new LCD or plasma TV. 40-inch models, a good size match for a 32-inch CRT (tube) model, are reasonably priced.
Jul 03, 2011 | Quasar SP-3233 TV
Pentax SMC D 16-45 Lens How to clean inside? Pictures are showing spots and all the outside lens have been cleaned along with the inside of the camera itself. Can not see the spots when taking pics only...
Your lens would need to be absolutely filthy with enormous dirt specks to cause the fault you describe. Dust, fingerprints, and regular minor debris simply doesn't show in the final image. In any case, you cannot clean inside the lens without dismantling it and that is a job for experienced specialists only.
Your fault is a dirty image sensor. You can buy sensor cleaning kits, but if you're inexperienced with them or trying to clean the sensor in a dusty environment you'll just make matters worse. Many camera shops offer sensor cleaning while you wait at relatively low cost. The reason you don't see the dirt when taking the picture is either because you're looking through the optical viewfinder or because the LCD screen simply doesn't magnify the image enough to show the marks which are present in the image.
You can prevent the dirt from reoccurring by never leaving the camera with the lens throat open for more than strictly necessary, and by always trying to keep the open lens throat pointing slightly down when swapping lenses.
I hope that I've helped, please take a moment to rate my answer.
Sep 16, 2010 | Pentax *ist DL Digital Camera
My PowerShot S30 has suddenly started to produce blue pictures
The white balance is set to something other than "auto WB".
Jul 22, 2010 | Canon PowerShot S30 Digital Camera
My son tripped over our friends ps2 and it fell to the floor upside down. The PS2 goes but the drive does not go.Any ideas how to fix this problem" Thanks
There are quite a few things that can cause a disc read error on the slim PS2. The most frequent is a bad laser, however, here is some useful troubleshooting info:
1. "Lid Closed Sensors" There are two "lid closed sensors" in the slim PS2. In a fall, it's possible that one or both have become damaged. Remove the top of the PS2 and try depressing both sensors with a game inside. The laser should move up and down at least???
IF YES, try again with the lid on... if the laser doesn't move when you close the lid, then the top casing of your PS2 cracked in the fall and is no longer depressing the lid closed sensors.
==> If the laser moves up and down OK but does not read discs, your laser was damaged in the fall. See below for a website with more troubleshooting info, pictures, and replacement cases and lasers.
IF NO, you have a bad lid closed sensor -- these are not really replaceable easily -- you may be better off replacing the whole PS2 if one or both of these lid closed sensors goes bad.
Nov 17, 2009 | Sony PlayStation 2 Slimline Console
Camera fell on floor and now wont open
Your camera would have to go back to Pentax or their factory rep for service. There is mechanical damage to the lens system and possibly to one of the circuit boards.
This type of damage will most likely not be covered by any warranties. These types of repairs can be very expensive in relation to the replacement value of the camera.
Jerry G.
Jan 02, 2009 | Pentax Cameras
Instruction manual for option S30
The s30 manual is 148 pages long and will take a long time to download but i will let you have a copy if you wish at no cost but a small donation to cancer research would be great
Oct 26, 2008 | Pentax Optio S30 Digital Camera
My pentax optio s has fell on the floor.
It is not likely that camera drop damage will be covered under warranty. But it never hurts to ask. Regardless, you will need to contact Pentax about repairs. Repair location information should be in the documentation that came with the camera. Their website shows service centers: Camera drops are not uncommon. Sorry to hear yours was damaged.
Aug 30, 2005 | Pentax Optio S Digital Camera
Pentax Optio S30 Digital Camera Logo
51 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
