Question about Uniden DCT646-3 Cordless Phone
Mic not working.
All of my Uniden phones are working well except for #3 which sounds fine but no one can hear what I am saying either with the intercom feature, incoming calls or outgoing calls. Please help.
  • Anonymous Oct 13, 2008
    THANKS MATE !!!! That totally solved the problem!!!!!!!
  • rtapales Nov 17, 2008
    I have the same problem - I had a total of 5 phones on two lines. 3 on one line and 2 on the other. 3 out of the 5 now have the same problem. I can hear the people on the other line but they cannot hear me. The only way to get it to work is if I plug in my headset!
It worked well for me too! Thanks Fixya.com!! I was told I had to buy a new phone because the microphone went back. Took the receiver apart (4 screws in back of handset and 2 that held the board in place), cleaned mic with alcohol and a q-tip, and removed the rubber piece that kept the mic clean (inside of the housing), and presto, it worked just fine. The ribbon cable came loose upon opening up inside of phone, but I stuck it back inside the top of base and I was ready to go.
Posted on Mar 09, 2009
I had the same problem with the uniden cordless phones, I have 4 recievers and only 1 phone was working, people could not hear me talk although I could hear them. I removed the cover and cleaned the mic and removed the rubber piece, all the recivers work great know.. thanks for the info. The model of my phone set is DCT646-3
Posted on Aug 23, 2009
    New Friend:
Thank you all. I had the same problem, i took apart the handset, and used some Old Spice After Shave (did not have alcohol or spirit) on the mic to clean it up. I also got rid of that black cover over it. The cleaning fixed mine up.
Posted on Nov 28, 2013
I had that problem, i took apart the handset, and used alcohol on the mic to clean it up. I also got rid of that black cover over it. I think the glue got all up in it and is stopping the mic from working. The cleaning fixed mine up.
Posted on Dec 14, 2007
Turned up full volume u can only just hear sound if ear right to it was working fine then the volume just ******** out
It could be the mic plug. uniden is known for the issue where the wires inside the mix plug break at the solder joints.
When the RX wire breaks, you will loose receive because the radio will not go into receive mode. But you can usually hear it ever so slightly if you crank the volume.
Other issue that may cause this. No radio activity, (unless you hear radio activity low and not static)
poor feed line or antenna.
I would try a different mic that is known to work.
Aug 11, 2012 | Radio Communications
When I call someone they can't hear me talking but I can hear them. What should I do to correct this. I haven't had any trouble with the phone before now. I have two phones and they are both having the...
the problem are on microphone,open up your phone check its first by tester then check the cable that related with the microphone.the phone have 3 mic ;1. earphone where we can hear people sound 2.mirophone that make people can hear our sound 3.Buzer for ringging.
May 21, 2010 | Uniden Cordless Phone
Microphone Problems
So people are hearing you but the sound is distorted. Change the mic and keep it farther away.
Feb 09, 2010 | EliteGroup P43T-A2 Motherboard
I can hear but the person I am talking to cannot hear.
try cleaning the mic' without openning the phone -
from the outside by an old touth brush...
that will do the trick
if you can open the screws without any damage
than pull out the mic's cover
it is probebly full of moist
Jul 22, 2009 | Uniden DCX640 Cordless Expansion Handset
I need help with my cordless handset
Replace the condenser mic on the handset.
May 23, 2009 | Uniden Cordless Phone
My mic doesn't work; callers can't hear me
I don't have the answer but have the same problem. Uniden tech support had me disconnect power, etc. to no avail. Next solution was "replace the unit". I'm looking for a two-line phone with no answering device - use voice mail. Any ideas?
Mar 14, 2009 | Uniden TCX905 Cordless Accessory Handset...
Phone works fine except the person on the other end can not hear your voice. Phone is a Uniden DCT 646 series cordless phone with one addional handset. The additional set is working fine.
There is an inexpensive built in mic where you speak into the handset. Ifit is not clogged with any debris, the mic needs to be removed with a soldering iron and replaced with a like one from Radio Shack.
Aug 23, 2008 | Lands Phones
Can hear everything except my girlfriend ):
Is it through an IM program? If so I had a simular problem and I open the sound settings and made sure non of them were muted and it worked fine after that.
Apr 23, 2008 | HP Pavilion dv6000z Notebook
Uniden DCT646-3 Cordless Phone Logo
1,020 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
