Question about Honeywell HE360A1027 Whole House Humidifier Humidifier
He360 humidifier, honeywell
Installed humidifier a week ago and it quit working,solenoid not working,120v to tansformer inside housing but no voltage coming out. Apparently Honeywell has a problem because I heard alot of complaints with the same problem. Where can I get one of these transformers in the future after my warranty runs out?
  • Anonymous Dec 29, 2008
    Sorry, I dont' have a solution. I've replaced my unit 3 times (under warranty each time). My answer was to buy an extended warranty from home center. Hopefully Honeywell gets it fixed in a subsequent version of the product b4 the warranty expires !!
SOURCE: Honeywell Humidifier HUT102m
its the worst design to fill it up that you could imagine. i was lost for a 1/2 hr trying to figure it out. well that 'easy to fill' feature on it means that you have to flip it upside down, balance it on its awkward shaped top, press in that spring loaded piece on the underside with one hand, and fill it (takes forever) with your other free hand in the same spot (apparently it opens up a valve that allows water in).
Posted on Jan 21, 2008
SOURCE: Honeywell True Steam Humidifier
Hire a certified heating specilist and pay for the installation. When you do, you are not only paying for the installation but you are paying for the many years of knowledge that goes into his or her carrer,
Posted on Nov 08, 2008
SOURCE: wiring low voltage
trying to find wiring instructions for honeywell he220a1019 whole house humidifier.
Posted on Nov 18, 2008
SOURCE: Continous ware flow on Honeywell HE220A Humidifier
I am having the same problem. I have had my humidifier for about 5 years now and I just started having the problem where the water continuously flows through the solenoid. I took apart the solenoid by removing the fittings from both sides. When I did that, I noticed that there was a hole in the metal that allowed me to see through to the other side. Apparently, it had corroded and and broken through, allowing the water to pass through the solenoid without really going through the valve within the solenoid. There are several sites that sell replacements for about $70, which is not cheap, but cheaper than buing a new humidifier for $120. Here is one site I found: http://www.iaqsource.com/product.php/honeywell/32001639-002/?product=112783&category=1142
Posted on Nov 20, 2008
SOURCE: he220a honeywell humidifier water actuator valve broke
My problem was the input water pressure (someone apparently changed it). I did, however, remove the unit and clean the filter which was pretty gunked up and that, along with adjusting the water pressure going into the solenoid, appears to have solved the problem.
Thanks to all who responded.
Posted on Dec 09, 2008
How to manually activate a humidifier solenoid
If humidifier is running but water valve is not clicking open, check the wire connections. If connection is OK, than unplug the humidifier from 120V outlet, disconnect water valve wires and with multimeter check resistivity on the valve coil. If the coil is burned out/open/no resistance, the coil needs to be replaced.
Nov 12, 2013 | Honeywell HE360A1027 Whole House...
He360 fan and water run continuously
Check yor wiring, make sure you have sail or pressure switch wired in series with humidistat to humidifiers 24V power. Pressure or sail switch will disconnect humidifier when furnace fan is off. Humidifier (110V) could be connected to any closest electrical outlet.
Nov 10, 2013 | Honeywell HE360A1027 Whole House...
Humdifier doesnt work. New solenoid valve two months ago. Water is not coming out of solenoid. Is it the transformer? Honeywell Humidifier.Model:
Check to see if there is 24 volts at the transformer when the blower motor kicks on, if not the transformer will need to be replaced. If you do have 24 volts then work you way from the transformer toward the solenoid and see where the voltage stops, could be the humidistat.
Dec 14, 2012 | Honeywell HE365 Humidifier
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
I don't think our h8908b honeywell humidifier is working. The house seems pretty dry. Kids are complaining of dry noses and throats. I have also been pretty dry nosed. How do I know if it is working? And...
Hello, if there is no water draining out of the humidifier than it is not working, The humidifier should turn on and off with the furnace, The best thing to do is have the humidifier tuned up by changing the water panel, making sure the there is voltage present the the solenoid valve, and making sure the water supply is getting to the solenoid valve. Let me know if you have any further questions I will be glad to assist you.
Feb 07, 2011 | Honeywell HE360A1027 Whole House...
I've installed a Honeywell 220A whole house humidifier. I've wired the humidifier, sail switch, humidistat and transformer according to the directions, but nothing happens when I turn it on. No water is...
push sail switch forward by hand to see if that is the problem.
Remove two wires at humidifier and connect them if it starts than it is in wiring, humidistat, or transformer.
Oct 14, 2009 | Honeywell HE220A1019 Whole House...
Water constantly running in honeywell humidifier
I has the same problem with my HE360 unit. The unit was in fact miswired. The head unit red wires were connected directly to the blue solenoid wires, and activated the solenoid without any signal from the humidistat. As soon as the unit is plugged inn, the water starts running without any signal to the unit. If your unit is miswired, the soleniod blue wires need to be cut and connected to the red crimp connectors.
Mar 11, 2009 | Honeywell HE220A1019 Whole House...
Honeywell HE260 housing melted/deformed
Humidifiers are made from a very durable heat resistant plastic. If it melted or warped you have a serious overheating problem. That plenum should not get over 140 to 155 degrees. If this furnace is running to hot it could stress and crack your heat exchanger. Install a good carbon monoxide detector in your home!!!! Check your filters. Check your airflow. Make sure all registers in the house are open. Is your blower speed set high enough? If this furnace is operating to hot it is definitely worth the investment to have a pro look at it before you replace the humidifier.
Is this overheating problem new? Or was this something thar happened years ago and may have since been solved But you are just now noticing the heat damege that was caused.
Goog luck
HVAC Teacher
Mar 07, 2009 | Honeywell HE260A1010 Whole House...
Wiring problem
Sounds like you may have put 120v through a 24v solenoid and humidistat.
Is the HUM terminal on the furnace 120v or 24v?
If it is a 120v terminal you will need a 120x24v transformer and a new solenoid and maybe a new humidistat.
Dec 19, 2007 | Honeywell HE360A1027 Whole House...
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
183 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
