Question about Mag Innovision LT776s 17" LCD Monitor
Pop up brightness
How do i get rid of pop up for brightness, lost my manual,
0 characters
1 Points
Keep getting waiting for automatic adjustment how do i get rid please
Most monitors give you the option to turn off auto adjustment - just go to the main when that pops up and select manual and you shouldn't get that pop up again.
Jan 26, 2016 | Computer Monitors
I constantly keep seeing "brightness 100"
Check out this link to the manual. It looks like your "On Screen Display" is possibly locked. This should help you unlock it if that's the case...
Oct 31, 2011 | Samsung SyncMaster T220 22 inch Monitor
How to get rid of osd lock on screen?
Try turning the monitor off, holding the + and - buttons for brightness and contrast and turn the monitor back on release the buttons.
Next if that dosent work hold the menu button down until the osd unlocked pop up appears.
hope this helps.
Feb 04, 2010 | Computer Monitors
Brightness menu keeps popping up
This problem is usually caused due to a faulty microswitch in the brightness button. To rectify this, you'll have to change this switch.
Get your monitor serviced by a qualified service personnel.
Hope this solves your problem. For more help or clarifications, please reply. Thanks.
Aug 09, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Dell 1900f monitor contrast/brightness problem
CLick start/run then type in dxdiag. Go to the display tab and click test dirext3d. There should be an 3d cube that comes up and spins around. After the cube leave cancel everything else and close dxdiag, Your problem should be solved for a pretty long time. If it happens again just follow the steps again.
Jun 11, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Auto adjust
i have had the same prob with a pl1700 would like an answer also
Jul 21, 2008 | Planar PL1700 17" Flat Panel LCD Monitor
Brightness control+blurrness of images+
no can do. you monitor is dead in the water.
lost of focus, and intensty. all point to one thing.
by the way, do you have the correct video driver installed???
Jul 01, 2008 | Compaq MV 540 15" CRT Monitor
Birghtness 100 Popup
sounds like your "brightness" button may be stuck. try pushing it and see if it feels the same as the other buttons (should feel it "click" a bit). Also see if any of the other buttons work, because if it IS stuck, they probably won't work...
Nov 29, 2007 | Samsung 710N V2 17" LCD Monitor
Adjusting Brightness on Acer 17 inch monitor
you change the settings manually using the up and down arrow buttons or plus or minus buttons mounted on the front of your monitor you dont need to use mouse.
Apr 04, 2007 | Acer AC711B 17" CRT Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
270 people viewed this question
Top Mag Innovision Computer Monitors Experts
William Miller
William Miller
Are you a Mag Innovision Computer Monitor Expert? Answer questions, earn points and help others
