Question about Gateway Computers & Internet
What type of replacement battery should I order for my Gateway laptop 400 series? The model number on the original battery is 4UR18650F-2-OA6 rechargeable Li-ion battery Rating 14.8V=4200mAh Tried finding this on your website but it was not listed. Please tell what kind I should order. Thank you
  • 25 Answers
You can pick up a replacement battery for that model in the following places:
Hope this is helpful
have a great day!
Posted on Nov 10, 2008
  • 689 Answers
You may try one of these 6500711, 6500712, 1528266, 61527196, 6500671, 6500710,3UR18650F-2-QC-OA1A, 6500663, 6500716, 6500718, 6500719, 6500760,6500761, 6500818, 6500819, 450SP, 450SX4, 450X, 450E, 450RGH, 450ROG,450XL, SQU-203, 400VTX.
You can get it from several locations like amozon, ebay and
What is the fastest compatible CPU for upgrade Asus X50GL series laptop
changing chips most time requires a mother board up date to cater for the extra chip pins
best advice here is to take it to a computer repair shop and they will be able to tell you right off if what you want to do is possible with that board
point of interest here
chips are only as fast as the hard drive and rams will work
if your unit has a disc type hard drive consider upgrading that to a solid state hard drive which handles data much much faster than a disc type
just a bit of info when you are talking to the computer geek
Oct 05, 2016 | ASUS Computers & Internet
Gateway wont power up the batt has been failing ,if pluged in the charging light comes on for a while then goes out if you try to start it tries then shuts down. could a bad batt cause this
If your battery is more than 2 years old, then it is a distinct possibility. Every battery type has a certain number of charge cycles (drain->recharge->drain) or time period. Lithium batteries run about 2 to 3 (tops) years. NiMH run about 10,000 charge cycles (or it could be 50,000 cycles if you know what to do). But if you're NOT using the original Gateway charger, then plug it into your laptop and see if it works. The 3rd party charger may have burned out the internal power components over time. In the worst case, you'll have to replace either the motherboard (hope you still have the product key!) or the motherboard's power connector, inside the laptop. At best, you might have to continue using the original power adapter. It will probably turn out to be a worn down battery, which needs replacing.
Feb 19, 2011 | Amstron Gateway P170X Laptop AC Power...
I need to purchase a replacement hinge for my Gateway MX6453 computer. When I contacted Gateway, they could neither give me the name of a supplier nor the number for the computer part I needed to replace....
1) One example of the Hinges,
2) Second example of the Hinges,
The Gateway MX6453 Notebook PC is part of the Gateway MX6400 series of Notebook PC's.
Here is the Service Manual (Free) for the Gateway MX6400 series of Notebook PC's,
Top file listings that start with Gateway 400, 450RGH, 600, 6000.........
Click on MX6400.
This is a PDF file. After you click you may not see anything happening for up to 30 sceonds.
Usually the first page pops up within 10 seconds.
Takes additional time for the file to fully download.
Suggest you let it download all the way before looking through it.
Need help in the steps to replace those Hinges, post in a Comment. We'll step by step it.
Nov 12, 2010 | Gateway MX6448 Notebook
My gateway M-7031U stops charging at 30%
Unfortunately your battery is probably shot. First though, try to run the battery down until the laptop dies. Now with the discharged battery, and the laptop powered off, plug it in and leave it off for a few hours. Power the laptop back on and check the charge level. Still at 30%? Then the battery is very likely just bad. Unfortunately, the cells in the battery just simply die for a number of reasons, and capacity is lost. This is why most manufactures will only warranty a battery for 1 year.
Take the battery out and write down the model number and the "MAh" or "Ah" number. The MAh number represents the capacity of the battery. The higher this number, the generally longer the laptop runs on battery. Go to and verify that this is your laptop model. This is a Gateway authorized reseller. Looks like they want $90 for a small battery. Take your battery model number and go to Amazon and look up the battery there. Make sure it's MAh number matches or exceeds what is on your battery. Usually you can get a replacement battery from Amazon for about $20 less than Gateway.
Oct 21, 2010 | Gateway M-7301u Notebook
Please tell me what the serial number an series number is for Gateway Laptop, T-Series, Model No. W350A?
the serial number is usually found at the bottom of your laptop, is not something that can be given to you online.
you may also want to try to do obtain your system info by going to
start>run> then type msinfo32 and press enter. a box will appear with your system info, it's possibly the your model number and other details that you may require could also appear there.
hope that helps!
Apr 21, 2010 | Gateway Computers & Internet
Gateway M Series M7301 M6885 Laptop DC Jack Adapter is Broken
The correct model number would help in order to solve the issue. Please see if you can locate the correct model number in order to help you.
Thank You,
Jun 11, 2009 | Gateway M-6885u PC Notebook
Internal wireless network
Go to the link below
You will see a list on things this guide will show you how to do.
  • Replacing the optical drive kit
  • Replacing the LED indicator panel
  • Replacing the CMOS battery
  • Replacing the hinge covers
  • Replacing the cooling assemblyHi
Jan 27, 2009 | Gateway 8510GZ Notebook
Motherboard Replacement
I would check Ebay you may be able to find a replacement one for cheap.
Jan 07, 2009 | Gateway MX3560 Notebook
Computers & Internet Logo
106 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
