Question about Pioneer DRM 6NX (DRM-6NX) 5.1 GB Removable Disk Library
Server Config Hallo, how to add the server inbuild ide drive to chache? the drive is very OK, but its partition didn`t seem to be useful for caching drm-6nx. i can access to files like flash and config Best regards Lutz
0 characters
1 Points
Buffalo LS CH1.0TL not recognised by computer on IP or USB
If you are using a Windows OS to access the drive, you will be unable to read the filesystem on this drive, as Windows cannot read XFS file systems which Buffalo uses.
Try downloading/booting off of a Linux live cd (knoppix, ubuntu, etc), they are free for download from their respective websites, and should be able to read that XFS partition.
May 05, 2011 | BUFFALO hop 1TB LinkStation Live Network...
If i press the reset buttom in the back of unit,would i loose my information inside hard drive
Here is user manual that explains about this d-link. Network storage servers are just enclosures that you add a hard drive to to be able to use it on network. per this d-link manual all the reset button is supposed to do is reset network storage its self. I would read on it a little just to be sure. Hope this helps.
Mar 13, 2011 | D-Link DSM-G600 (DSMG600) Network Storage...
Hi, few days ago I bought a Netgear NAS 2110 and connected it to my Netgear WNDR3700 router. I installed RAIDar utility and followed the instructions. Everything seemed to work alright. From my laptop I...
If it's new it's probably doing some housekeeping. The drives need to be formatted and then the RAID arrays need to be sorted.
On installing my server, it took days to complete, however, that was with existing data on the drive.
It might not be letting you switch off because it's busy and doing so would mess up what it's trying to perform.
If you don't want to wait to find out if all is OK, go into the configuratio utility and set just one drive up. This will show if it's working as a unit. If all is fine, install the remaining drives, maybe one at a time.
Dec 30, 2010 | NetGear ReadyNAS Duo RND2110 NAS server...
How do I configure it?
Use its ip address or its snap# to browse into it using Internet Explorer ( http://snap30123 ).The default log in is administrator and no password.
If the password is changed, hold down the reset button for 15 seconds and it shoud reset to default.
Jan 25, 2010 | Quantum Snap Server 4000 (5325301085) 30...
Hello , HP Proliant Server Problem.
Use a different monitor and connect it directly to the server, if problem persist you have a problem with the systemboard or microprocessor.
Jun 29, 2009 | HP ProLiant DL380 G4 36 GB Network Storage...
Sound card in Server
Yes, just make sure the card is compatible whichever flavor(s) of slots you have available and is supported by your OS.
Nov 28, 2008 | HP ProLiant DL380 G4 36 GB Network Storage...
Adding additional drives to an MSA20 unit,
1- Turn Off MSA and server
2- Insert new disks
3- Turn On MSA first then server
4- Access ACU and new HDD will be listed
Nov 21, 2008 | HP StorageWorks MSA20 (0808736947138) Hard...
CanĀ“t use INTEL SS4000-E to host the files of my database from SQL SERVER 2000
The SS4000-E  is a NAS storage server.  To the best of my knowledge it is not possible to put database files on a NAS.  They need to do on Direct Attached Storage.
Oct 22, 2008 | Intel SS4000-E (SS4000ENA)
NAS 200 D 480 Gb , it doesn't boot: how to recover data from second partition
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Feb 18, 2008 | Iomega 200D (33060) 160 GB Network Storage...
Toshiba Magnia SG20
do you have an admin icon on your desktop?
if not type in the ip addx and see if you go to the admin.
on network connections , right click on my network places, click map network drive,
select a drive letter and then browse for the two folders on the "myserver" select one of them and click apply or ok. the drive will show up in mycopmuter do the same for the other folders
as far as the log in is concerned it is best to set a level 3 user name and pw on the server then do the same user name and pw for a new windows login user.
Nov 20, 2007 | Network Storage Systems
Pioneer DRM 6NX (DRM-6NX) 5.1 GB Removable Disk Library Logo
24 people viewed this question
Top Pioneer Network Storage Systems Experts
Jose Cada
Jose Cada
Are you a Pioneer Network Storage System Expert? Answer questions, earn points and help others
