Can`t get wireless router to connect to pc. Have uninstalled/installed usb wireless adaptor no good. Router works fine on a wired connection on another pc nearby.`Wireless` pc 10m away from router has worked fine on a bt installation. toolbar shows repeated attempts to connect. Help ! Richard
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    try 192.168.1.1 or 192.168.1.0 in the browser or the IP address if mentioned on the router..letme know if it helps
    Problem Solver:
  • 6 Answers
  1. Go to "Network Connection"
  2. Click Right "Wireless Network Connection" Go "Properties"
  3. Click at Internet Protocol(TCP/IP) and click "Properties"
  4. At General bar,. Click on Obtain an IP address automatically and Obtain DNS server address automatically and Alternate Configuration bars, click Automatic private IP address
  5. After all of this click "OK" and "Close"
  6. wait for 30 second and try to connect again
Posted on Nov 10, 2008
Usb adaptor
you might be knowing about it... but check--
Yes you an can but the purpose of the Wireless Usb adapter is to get the wireless connection from the Router to the PC (Computer)
Connect the Wireless USB Adapter to the usb socket of the computer and install the Drivers with the Help of the CD.
Note to get the wireless connection you need the wireless router connect as well in home network
Jan 24, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Cannot aquire ip address from wireless router
Hi, If your newer usb wireless adaptor does not have the same settings as your router this is the problem you have. First make sure you have installed the cd software that came with the usb adaptor without it plugged in. After that is complete make sure the wireless adaptor is seen by the computer it is attached to. Then you need to open the settings of the usb adaptor and set it up same as your router's settings. This includes the WEP security password if you use it. Good Luck.
Sep 19, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
TEW432-BRP Trendnet wireless broadband router wont connect
Sounds like you need to configure the PC's USB wireless adaptor. The settings must be the same as the router. If you use a WEP password on the other connections then you need to have the same password on the USB wireless adaptor. Good Luck.
Jun 30, 2009 | Trendware TEW-432BRP Wireless Router...
NETGEAR Wireless G USB Adaptor Problems
I contacted Bigpond after my whole internet collapsed due to my amature abilities in fixing the internet. >_<" yet they fixed my internet connection by disconnecting my current (DLINK DIR-300) router from the network. hmmmm... the technician also confirmed that my current broadband modem (2WIRE 2071-A) isnt capable of supplying a shared connection to more than one computer!! she also directed me towards a modem with an inbuilt wifi router that "supposedly" is the best option right now. (2701HGV-W) I'm a bit shaky and the stupid NETGEAR adaptor problem still exists - im willing to buy the new modem if its guaranteed to abolish this problem and give me a better internet wise outlook - please any suggestions will be appreiciated =)
Apr 23, 2009 | NetGear Wireless-G USB Adapter...
Cannot connect my wireless adapter to Belkin wireless router
hi,
ok sir i got it if the wireless network is detected then try and connect and the if it doesnt connect try and connect in safe mode with networking sometimes wireless doesnt work in safe mode,but still try that,uninstall and reinstall the wireless driver for adaptor and then open the gui page(router page with the default gateway page and then change the wireless channels and also turn off the firewall,and from the start,all programme turn on the wireless adaptor utility and then start the services of wireless zero configuration from services.msc.....then if it is connected with the ehternet cable,then what u can do is that go to the router page and then also put a check in the let the windows controll the wireless network......and it will definately work and if it doesnt work then reinstall the operating system......good luck...
if it is a little bit also helpful pls.rate this soultion for me pls.....
Feb 07, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Netgear 108 wireless usb adaptor
This is a driver problem, it may be windows generic driver that has installed; so if you have already installed the software, uninstall it and remove the adapter. Restart the pc, then insert the cd driver, but don't let it autorun, then re connect adapter and this time when it asks for the driver point windows to look on the cdrom for it instead of allowing the cd to run the installation.
Jul 12, 2007 | NetGear USB 2.0 108MBPS Adapter 802.11...
Wireless cannot detect any network despite claims to be working fully
Try first dissabling the wired network adaptor, so as the pc is not looking for the wrong area connection. If you have used Windows to try to repair the connection the settings will be wrong for the router addreses. Go to your wireless network cards properties and make sure that on the internet protocol the obtain IP address automatically is selected. Run this flush:- Click Start>Run, then type ipconfig /flushdns then press enter. Re-start pc and type the routers address in your internet browser. Go to your router settings and ensure enable DHCP is set to automatically allocate ip addresses.
Jan 23, 2007 | Acer FerrariI 3400 Notebook
Computers & Internet Logo
David Payne
David Payne
