CD Player My 12 year old Magnavox CD Player will not play the CD stored in it.  The screen has DEF displayed.  What does that mean?  How do I fix it?  How do I get my seven CDs out?  Thanks
  • 1 more comment
  • vpwelsh Nov 10, 2008
    Thanks, but I have done this a number of times.
    The solution from Thafa does not answer my questions.  What the heck is a lens?
    Solution by rush2robby.  What is a sleep?
    Scholar:
  • 53 Answers
From what I can see, two things needs to be tried, 1 get the cd's out & 2 try to get the system to play cd's in the future.
first take the unit apart making sure tht it is unplugged from the mains, before you start. most of these types of systems are a bit fiddely so make a mentle note of what goes where, you clearly are aiming for the cd draw, I should be quite straight forward but be very careful that you don't tug any connections away for the boards.
once you get to the cd tray you may be able to look at the mechanics toactually see what the physical problem is with the draw, ie broken drive belt etc. repair if you can (easier said than done in some cases)
to clean the lense the link below shows a lense from a Playstation 2
http://images.google.co.uk/imgres?imgurl=http://www.steveselectronics.biz/products/cd-lenses/images/PS2.jpg&imgrefurl=http://www.steveselectronics.biz/products/cd-lenses/sony/sony-cd-lenses.html&h=190&w=345&sz=14&hl=en&start=14&usg=__ISw9e64VyAU04E8mfsivGaXI-0c=&tbnid=AgO2CODAQzIW-M:&tbnh=66&tbnw=120&prev=/images%3Fq%3Dps2%2Bcd%2Blense%26gbv%3D2%26hl%3Den%26sa%3DG
it's the blue glass bit shown in the image on the far left hand side. either try and clean with a lint free cloth or just give it a good blow. or physically remove any lint or obstruction that you can see.
then reassemble the unit.
if it still does not play CD's then at least you will have retrived your cd's.
hope this has helped in some way.
Posted on Nov 10, 2008
    Sergeant:
    Novelist:
  • 196 Answers
Its the problem of the lens which reads the cd which you insert in the player.if that lens has got dust on it or any moisture collected on it due to humidity problem then also it shows same error. if the lens is faulty changing the lens is the only option.but for dust or moisture cleaning the lens with a moist tissue will help.for the cd stuck it you can open the screws on the back side of the device and remove the front cover and proceed further from there and that stuck cd can be removed.also get your cd checked in some other device and confirm if it is working properly or not.if the cd is faulty then also it shows this message.
thanks.
  • mmechanics Nov 10, 2008
    How to Clean the Laser Pickup Lens on your CD Player
     If you need to clean the laser pickup lens on a CD player, follow these simple steps.
    Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails.
    Remove the outer casing of the CD player. Remove the screws that mount the top casing onto the bottom of the CD player and slide the top casing off. This will expose the CD deck, which houses the laser pickup lens.
    Find the lens. The lens will be glass and under the CD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection.
    Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab.
    Give the lens a few seconds to dry and replace the covering of the CD player. Test the efficiency of the player. If necessary, repeat the process
  • mmechanics Nov 11, 2008
    tell us taht till where have you reached in solving your problem .so from there we can continue helping you further to resolve your problem.
    thanks.
    Genius:
  • 1,239 Answers
Hi you seen by changing other cd"s
  • 83 Answers
Your cd player having err in the ejecting belt you need to replace it, a simple way out to remove cd from cd player,  Give a small sleep upside to your cd player then cd comes back, and then try again
  • rush2robby
    rush2robby Nov 10, 2008
    sorry it is not sleep its slap
    Sergeant:
    Champion:
  • 200 Answers
Hi
clean the lens and then check it..
If its not work means...
Check whether ur player is read the disk.
If its ok means then u need change the lens..
If its not read the disk means then their is a problem in circuit board..
Thank you
  • Thafa Nov 11, 2008
    Hi
    Sorry for my previous solution..I thought cd is not detecting...
    when the cd rack(door) is hanged means ..
    U want to check the motor when motor fails the cd rack will not operate..
    If motor is ok means then u want to check the belt and the gear system..
    Thank you
    Genius:
  • 1,269 Answers
First try to unplug the power source of the unit for 5-10 minutes. Then when you plug it back in, hold the power button for about 10 seconds. Now try to eject the CD. Or try to play it again.
Repairing coby cx-cd118 cd player
hi there.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. ... If theCD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
How to Fix a CD Player That Skips ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
cd player skips Google Search
Nov 27, 2017 | Coby Lands Phones
Hi I have a panasonic stereo SU CH 80, it's the
It means error, this usually indicated when you have a CD player that can't play the disc.
Apr 02, 2012 | Panasonic Audio Players & Recorders
99 Jeep Grand Cherokee. Radio and tape player works fine. Inserted 10-cd magazine and can hear cd's loading, but no light display on radio when cd button pushed. Is this fixable?
yes but why fix a 12 year old player ? something else will just go wrong after that heck cd players are cheap today and fit right in that opening
Mar 11, 2011 | 1999 Jeep Grand Cherokee
When a cd is inserted it displays 'no disc' and am unable to play the cd. I have tried several different cd's both new and old and same issue. CD player is almost 20 years old but if a simple problem to...
More than likely with a cd player that is as old as this one is the laser may have gone bad. If you can find a replacement laser component it can be replaced. Or it could be as simple as getting a cd player cleaning disc from just about any store and cleaning it.
Jan 06, 2011 | Sony Electronics - Others
Movie DVD'S
make sure the dvd player is region 1.
Aug 20, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd player wont play dvds
Just first clean the optical lens of the unit. use a cd optical disc cleaner for this.
Nov 20, 2008 | Televison & Video
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox Mini Hi Fi System
My FW14 MX 3701 CD Mini Hi Fi System will not play The CD stored in it.  The screen says DEF. Thanks.
May 16, 2008 | Audio Players & Recorders
Pioneer cdx 12 disc changer
According to manual code simply means electrical or mechanical fault - not extremely helpful.
Try to disconnect and reconnect power and it perhaps will reset the problem.
Feb 03, 2008 | Pioneer CDX-FM1289 12-Disc CD Changer
Magnavox DVD player mwd200f
I would start by replacing the cable from the DVD player to the TV, sounds like a break in the cable, or the plugs are dirty, also, just a precaution, use a CD cleaner.
May 08, 2007 | Philips Magnavox DVD Player MWD200F
 Grubhead
Grubhead
