How can I eliminate audio Hum from Onkyo TR-SR705 AV Receiver?
I am trying to use a new Onkyo TR-SR705 AV receiver. When first setup, I noticed a low 60Hz hum without any of the inputs active, and a louder hum when the "phono" select is made on the receiver (even though the phono was turned off and is grounded to the receiver). The hums were the same from the front speakers and from headphones.
There are no video output connections. I am trying to solve the audio hum before completing the theatre setup.
After removing all inputs (including antennae), and all speaker wires, the hum on the headphones is the same. Moving the unit to another power circuit made no difference.
Can there be any conclusion other than that the receiver is defective?
    Genius:
  • 1,550 Answers
Is there any hum in Direct and Pure modes ?
If there is no hum in direct and pure modes .
Then it is bad processor board .
You need to contact ONKYO
Hope this helps .
Posted on Nov 10, 2008
    Genius:
  • 1,239 Answers
Hi the problem is with reciever only you should change its freqency signal or the problem may be with input connections itself
  • ABHISHEK.C
    ABHISHEK.C Nov 10, 2008
    or there may be short circuit
    Genius:
  • 1,269 Answers
There might be a grounded component inside the circuit board. Hopefully its just a wire that needs to be resoldered. Better check the internal of the unit for visible loose component or parts connection.
TX-SR705 60 hz. Hum
If you have a Home Theater Line conditioner on this receiver, not a power surge protector, even a "Monster" surge suppressor, your problem Is AC related. For troubleshooting; first if your AC power cord is three pronged, go to Lowes, Home Depot, etc. and get a three prong to two prong adapter. Your problem is a "Ground" issue, however it may not be from the receiver, it could be "Anything else" in your home. Even an actual outlet with a loose wire. It can be very very time consuming to "hunt down". An adapter will take the rest of the house out of the picture. Disconnect all other input sources like Cable, DVD, etc. then turn the unit back on. If you still have a humm, yes the problem is internal and needs serviced. If it stops, re-connect one item at a time until the noise re-appears and you have your culpret. If you don't have a line conditioning noise eliminating Theater surge protection unit; Get one! best few hundred bucks you could ever spend. It will protect all your electronics and could save you thousands! Panamax, Furman, Monster, are your top 3. If you still have issues, post a comment and I can help you further. Hope this helps.
Aug 23, 2009 | Onkyo TX-SR705 Receiver
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Don't want to use receiver to turn Plasma on via Verizon DVR
You can not have a signal from cable/satelite TV when reciever is OFF.The only way is reconnect by using defferent setup configuration to illiminate the receiver.In that case you well see just regular Tv program but you should connect antena to your TV.
Apr 17, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Apr 15, 2009 | Onkyo TX-SR705 Receiver
"The blue light around my volume dial does not light
Try resetting the receiver (you will lose your setup). I recently reset my receiver and the blue light returned. It's possible that the Audacity setup turns off the blue light because the volume is now being "regulated" by the equalizer.
Mar 26, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Mar 04, 2009 | Onkyo TX-SR705 Receiver
My onkyo tx-sr705 produces a humming noise out off all the speakers when no audio is played
I found the source of my hum. I have Direct TV HD. I found that going into the menu settings (Direct tv HD Receiver) /Audio/Sound Effects and turning that option off, I was able to rid myself of the annoying hum. The option has something to do with keeping the audio settings from channel to channel, while it is changing you hear dead air except for the hum. Nice and quit now. Love this receiver!
Mar 06, 2008 | Onkyo Audio Players & Recorders
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
