Question about Samsung SyncMaster 245BW Monitor
245BW Snap/Crack sound and then does not work
The subject says it all... I was filing some papers - nothing unusual going on - heard a very sharp snap or crack sound and the monitor was no longer working. The power button was still working and getting electricity, but a dead screen. Any ideas what this could be? I'm pretty handy with repairing PCs and I was able to get the back cover off with no problems, but couldn't see anything obvious.
Thanks for any help.
  • al-r Jan 03, 2009
    I have just experienced a very similar problem. Suddenly this morning my 245B just woulnd't show anything.. the screen is completely black, but not an illuminated black, black as if it were just turned off constantly. The only difference between its current state and it being turned off is that the power button seems to work as normal so I assume it's not a power source problem.
    I also have heard it 'crack' various times throughout the last few weeks(?) after approx. 45 minutes of usage when first turned on, and sometimes after it is turned off, but this didn't seem to have any effect, so I ignored it.
    Jmassengill, have you managed to fix your problem?
    Thanks
    Adam
  • 345 Answers
Be very careful! Some monitors/TV's have 30,000+ volts DC in them even when not plugged into AC house current. The crack/snap sound was most likely an electrical component breaking down and shorting against the metal of the case of the monitor. I would take the monitor to an authorized repair center because the danger of getting shocked/killed is very possible while working on this type of problem at home.
Posted on Nov 10, 2008
I have the Toshiba Theaterview. Was watching it when I heard a sound and the screen went black. The Red Light will come on and glow steady and you hear it click when you try to turn it on or off but...
Something is causing the TV shut down or go in to 'protect' mode.
It is unusual to actually hear a component inside the TV go bad, but you obviously did. Probably in the main power supply or something that normally uses a higher voltage in the TV since you heard it..
Jan 25, 2015 | Toshiba Televison & Video
I heard something snap and then noticed that the rear of the car drives very bumpy
Can you provide more info? Did you hit a bump? What do you mean by 'drives bumpy?' Does it ride rough, or does it go up and down a lot after you hit a bump, or something else? Can you further describe the snap you heard, and what was going on when you heard it and immediately afterward (e.g., driving 40 mph on a paved road, hit a pot hole, heard a loud 'breaking' sound as if something snapped/broke, and the ride of the car seemed to immediately change to being more harsh/rough)? Have you had any work done recently, such as tires changed or rotated, struts replaced, wheel alignment, or brakes replaced? Did anything else change (e.g., now when you hit a bump, you hear a new noise in the rear)? Were you carrying anything heavy in the trunk or back seat? I had a '99 Corolla for several years, and had zero problems other than a worn out driver's door handle and a couple of cracked windshields. Great car choice!
Jul 18, 2014 | 2000 Toyota Corolla
Sharp MX-2300N constantly sounds like it's feeding paper. It will feed paper just fine when it's actually printing something but it will still sound like it's printing something but nothing ever happ
The fuser will occasionally turn on and run to keep itself at 400 degrees. You can change the 'time to sleep' for both the fuser and overall copier through the Energy Saver admin level in the System Settings. If the fuser is running way too often, the thermistors may be insulated with a layer of toner which can be scraped off. If after a print or copy job, the machine still runs for 5 seconds or longer, you may have scrambled firmware needing a reflash.
Jun 03, 2014 | Sharp MX-2300N Color Copier
Makes loud noise
It sounds like one of your CV (constant-velocity) joints is going bad. This is common on front wheel drive vehicles. The CV joint allows the drive axle to pivot as you turn the wheels. Over time the protective boots crack, the grease leaks out and you end up with the knocking noise you describe when turning while accelerating. The dealership should easily be able to inspect the CV joint boot and diagnose the CV joint.
Mar 05, 2014 | Mitsubishi Outlander Cars & Trucks
55"sharp aquos led flat sreen and its making a
Can it be heard with sound off and describe the sound a bit, buzz or high pitched sound? Not unusual for the front screen unit to make a slight buzz but I gather this is loud.
Dec 13, 2012 | Televison & Video
WILL NOT MAKE SWITCH FROM CUBE ICE TO CRUSHED I CE
remove bucket,empty into large bowel. inspect bucket opening,and be sure ther are no chunks of ice hindering movement of blade bypass mech. w/bucket out operate ice disp on crushed and cubed selections,listen for sharp snapping sound before motor turns.if sound is heard,reinstall bucket,and you should be good to go
Mar 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No power on sharp aquos. no lights nothing.
Sounds like a power supply issue, very unusual for LC32D40U. Part number for the power supply: A3Y101E240.
Feb 17, 2010 | Sharp Aquos LC-32D40U Television
TURNED ON, HEARD A CRACK SOUND, NOW JUST A BLNKING RED LIGHT? PRIOR TO THIS THE COMPUTER WORKED FINE!---MONITOR WORKS ON ANOTHER COMPUTER....I GET NOTHING ON THE SCREEN & THE DISK UNIT DOESN'T...
If the power LED is blinking red, that's usually the PC telling you there is an error. Is it an HP/Compaq? The number of blinks can tell you what the problem is. If you heard a crack sound when you turned it on, I'm willing to bet the power supply went. You can go to the manufacturer's website and look through their Support Information and see what the red LED tells you.
Oct 03, 2009 | Computers & Internet
Broken Monitor
Hi Roeder, I have never heard of an LCD screen cracking from anything other than physical force, this is a first for me. It is possible since there is high voltage power in there for the backlight. In light of the sound I suspect a component failed, generated lots of heat real quick and caused the crack/failure. This is really unusual and you might try calling Gateway to see if they will replace it, especially if it is one year or less old. I would resist all temptation to open the LCD till you call Gateway. If they will replace it they won?t be happy to find you opened the case. Let us know how it works out and please don?t forget to rate this post.
Feb 02, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Snapping sound
Could have a shorted gun, or a small crack in the neck of the crt
Nov 03, 2006 | Apple M6496 17" CRT Monitor
Samsung SyncMaster 245BW Monitor Logo
224 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
