Question about Tecnik TKL9260 Front Load Washer
Leak at from drawer
I have a Tecnik TKL9260 and all was working well until i got a banging noise. Eventually it just stopped making a humming noise. I disconnected the power and taking of the back of the machine saw the belt had broken and the earth(green and yellow) tangled in around hte motor drive shaft. I untangled the mess and ordered a new belt. The new belt looked small to me though was assured its the right one and I eventually got it on with much effort. I taped the earth cable back from the motors drive shaft. When I turned the washing machine on it seams to work ok, It fills with water however starts with a lot of noise. Eventually when it spinns the water starts coming out the detergent drawer but not when its filling with water.
Has anyone any ideas what my next step should be?
Thansk in advance
John
  • macsbac Nov 10, 2008
    I think this could be a cycle problem, the drum seams to be spinning around completely in the wash cycle, when it should just be going side to side. The result is the water is going back up into the detergent drawer.
    Is there sime way to adjust the cycle?
    John
  • 43 Answers
Sound like its taking in too much water if you look in top of your machine you will have a thin rubber tube coming up too a pressure switch i think this switch may be faulty
Posted on Nov 10, 2008
Frequent leaks through soap drawer during rinse cycle
Possible that the dispenser drawer is out of alignment or is the suspect. You can remove and check the mountings
click on : Dispenser
Jan 24, 2013 | Tecnik TKL9260 Front Load Washer
Please may I have a Washing Machine manual for TKL9260
Free tech support for Tecnik TKL9260 Front Load Washer and help with Tecnik TKL9260 ... Where can I find a manual to download for this machine please. www.fixya.com/support/p31758-tecnik_tkl9260_front_load_washer www.fixya.com/support/p31758-tecnik_tkl9260_front_load_washer
Jan 26, 2012 | Tecnik TKL9260 Front Load Washer
Machine wont drain
check for faulty water pump or a blockage to the water pump see if you can here a hum when it is time for the machine to drain
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 18, 2010 | Tecnik TKL9260 Front Load Washer
Hi We have a problem with our Fisher &
First is to make sure there is no leak. Pull out the lower tube, access from the left side only this side you can put your hand in with a small tower to dry out the wetness if there is. If it is wet dry out really good then unplug the power cord for 24 hr. After that plug power cord back. Hold the lock button while press the Start button until you see a display appears. Press the Power button to see a clear display. Then hit Start button one by one until you see Ld ( it stands for Lid down) If you miss it, keep going until it comes back in a loop. When at Ld hit the lock button. Wait until the noise is stopping. Hit the lock button again. Wait until the noise is stopping. Now you can pull out the top drawer and press the power button to get out this manual mode. Good luck.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Powder and comfort not going throught properly/always some left in the draw
hi there....remove and clean soap dispenser drawer....paying particular attention to the area beneathe the drawer....cut down on the amount of detergent and comfort you are using
regards Sir Galahad
Aug 21, 2009 | Tecnik TKL9260 Front Load Washer
Tecnik tlk 925 washing machine not spinning
sounds to me like your carbon brushes have worn down if they wear down too far they will hit the metal casing that explains the grinding noise
Aug 08, 2008 | Tecnik TKL9260 Front Load Washer
BAGGING NOISE WHEN SPINNING
try moving the clothes around it might be an unbalanced load.
Jul 30, 2008 | Tecnik TKL9260 Front Load Washer
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Tecnik TKL9260 Front Load Washer Logo
89 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
