Question about Kitchen Ranges
Require new oven grill knob and flame safety device to be instaleed on a Model G716 WH
  • 1,122 Answers
Go to,click on parts,put in your model number and see if they have the part you need-mike
Posted on Nov 11, 2008
Push knob in on oven sparks & lights release knob flames go out
Often on ovens you have to hold the knob down for a period of time before the flame will stay alight.
Try getting the oven lit then holding the knob down for 30 seconds. That should be more than enough time if that is indeed the problem.
Is it a new oven or has the problem just arisen? It
Jul 23, 2015 | Ovens
My oven ignite when i press the knob for 6 second to make it work after i release the knob it turns off
There is a safety thermocouple that requires the gas to be running a flame to keep going. Its called the "flame failure device". Yours is not working. Talk to an appliance engineer.
Nov 02, 2014 | Ovens
First, Change your technician.
There is a part that senses the heat from the ignited gas, usually quite close to the flame on the oven burner where it first ignites. It is called a generator and it produces about 1/3 of a volt, that holds the gas valve open only while the flame is lit, as a safety device. Pressing the knob at the time of ignition bypasses this by holding the valve open, after releasing the knob then the system relies on the presence of an oven flame to hold the valve open. Check the generator at the point it enters the oven control valve, is it loose? Maybe it is faulty or the oven valve is faulty. Any real technician can identify the the problem easily.
Oct 31, 2017 | Candy Washing Machines
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
The temp/flame on my weber grill won't get hotter
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly.
Mar 06, 2009 | Weber Spirit? E-310 Propane Grill
Low flame and not heating oven
we had the same problem on our 10 yr old creda. gas man said new ffd required (flame failure device). he reckoned on around 80 pounds sterling for new part,even if it was still available, plus maybe 2 hours labour. we bought a new cooker!
Nov 24, 2008 | Stoves 1000DFDLm Gas Kitchen Range
Low and Slow heating to temperature on grill
Here are some tips:
Check: The excess flow safety device, which is part of the barbeque to cylinder connection, may have activated.
Fix: To reset the excess flow safety device turn all burners control knobs and the cylinder valve OFF. Disconnect the regulator from the cylinder. Turn burner control knobs to HIGH. Wait at least 1 minute. Turn burner control knobs OFF. Reconnect the regulator to the cylinder. Turn cylinder valve on slowly. Then use your like you normally do.
Now the line is purged.
Apr 29, 2008 | Weber Genesis Silver C Grill
My gas oven flame
May 28, 2007 | Parkinson Cowan SG320 Gas Kitchen Range
Kitchen Ranges Logo
146 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
