Question about Brother IntelliFAX 4100 Laser Fax
Dark Bar only on Sent Faxes
I am getting a 1" dark bar all the way down pages that are sent only. I do not get this on faxes I receive. I have changed the toner, drum and used canned air to clean the entire inner sections of the fax machine. I have also cleaned the with with the blue thingy.
Any suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Open the top where you insert the paper to fax look at the strip of thin glass is there any white out or toner on it that is most likely your line, clean
Posted on Nov 10, 2008
How can i Troubleshooting Fax Issues on my hp officejet 4650?
If you get issues like Faxes can be sent but not received, Faxes can be received but not sent error on your Printer then follow the given troubleshooting steps.
Solution to Faxes can be sent but not received
    ·Initially, you have to check any of the telephone line services are enabled. There are,
    1.Voice Mail
    2.Call Waiting
    3.Billing Tone
    4.Privacy Block
    5.Security Screen
    6.Anonymous Call Rejection
    7.Privacy Manager
    ·These may block your incoming faxes. So disable the above features.
    ·If you are using Automatic fax reception option on your fax recipient, then check whether the Automatic Answering feature is enabled or not, if it enables means Auto Answer green LED should be on.
    ·Check the Ring to Answer value.
    ·If the value set as answering machine that causes the issue on fax reception. Then change the value to Fax or FaxTel
    ·Now, you can receive the incoming faxes.
    Solution to Faxes can be received but not sent
      ·Check whether the dialed number is correct or not. Every one of the digits required to make a telephone call from a similar line must be dialed.
      ·On the off chance that the Speed Dial has been used for dialing or the fax has been sent from your PC, print the page to be faxed and dial the number physically on the HP Fax front board.
      ·Check whether the Tone Dialing is set on you HP Fax product.
      ·In the event that faxes are sent effectively from the HP Fax front board, but, it's fail when sent from the PC, test the communication between the HP Officejet 4650 printer and your PC by tapping the Status button in the HP Director application, or attempting to print some record.
      ·If the printing fails to send the fax, then check whether all cables (from system to HP Officejet 4650 Printer) are connected properly, if it's not then connect it properly.
      ·Now restart it. On the off chance that communication still can't be set up, Call Printer customer service team via Toll-Free: +1-800-836-3987 to resolve your HP Officejet 4650 fax issues.
Jun 27, 2017 | HP Office Equipment & Supplies
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
Dark band on left hand side of incoming faxes
Your toner cartridge is leaking toner onto the transfer roller. There is no cure except for replacing the cartridge.
Dec 10, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Thick Dark Line on received and copies of faxes
don't know the model of machine, but usually caused by the drum unit or toner cartridge. many machines have both drum and toner in 1 unit. try replacing.
Nov 18, 2009 | Televison & Video
All in one x7550 is leaving wide black lines on copies and even on faxes sent out--what's the problem??
The problem is likely the scanner. Both copies and faxes are scanned. Tell it to scan an image. Lift the top, so you can watch the light bar go down the page. Its most likely got a dark area.
If under warranty, make arrangements to get it repaired or replaced. If not it may cost as much as a new printer. It has to be taken apart to replace the part.
Oct 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Lazer Jet 3150 fax machine out going faxes have 2 lines on them
I went online and printed out the methods to clean the fax machine and lo and behold it worked
Mar 30, 2009 | HP Office Equipment & Supplies
Sent fax
the question is Why can't they read it????????
compressed, dark, light.......???????????
Aug 19, 2008 | HP 1010 Plain Paper Inkjet Fax
Canon i-sensys fax-L100
The machine keeps in memory only reports of faxes sent or received until the page is full.When the report page is full, the earliest fax is removed to make way for the most recent. Therefore if you sent enough faxes after 4 Apr 08 to fill a page, there will be no record.
Aug 18, 2008 | Canon FAX-L1000 Plain Paper Laser
Faxes sent through HP 3050 is unreadable
Following could be the reason behind this issue:
1. Check ink cartridges of the recieving printer.
2. Make a copy from your printer,if there is any problem while copying then replace the printer.
3. If the copying is not fine then clean the scan feeder, andif it is fine then it is an issue wih the other printer.
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Brother IntelliFAX 4100 Laser Fax Logo
100 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
