Question about Olympus Camedia C-60 Zoom Digital Camera
Lens wont retract, makes noises, error code on blue screen D:1E 1A
My camera makes funny noises, the lens wont retract and the error code D:1E 1A comes up. now the code 1E 1A 1E 01 1E 11 1E 1A comes up. Ive charged the battery fully but it dosent make a difference and i have since brought a new one but it has made no difference. please help with any advise!
  • 1 more comment
  • Anonymous Dec 08, 2007
    the same problem!
  • Rondalou Jan 05, 2008
    I have same problem...help please!
  • Anonymous Jun 15, 2008
    I also have the same problem. I think it may be the motor or something has stuck in the lens (i.e sand, grit etc) making it impossible to retract
I have one of these and I dropped it with the upshot that the lens jammed.
Playing with it I found that the forward (smaller) part of the lens sits in a sort of groove in the outer part and when I manipulated it back in its worked fine ever since.
Chris, England
Posted on Jul 14, 2008
I posted the same problem on the 15th June and in the meantime I have been playing around with the camera. After holding the camera upside down and gently tapping the back of it, the lens decided to work and retract back into the camera. Not the most technical advice I know but it seemed to work.
Posted on Jun 29, 2008
My camera lense is stuck out and when I turn on the camera it makes a funny noise and says "lense error" on the screen. Is there anything I can do to fix it myself before taking it to get fixed?
Sounds like the camera lens is jammed. Before you take it to become repaired, try cleaning the crevices of the lens module to make sure there isn't any loose dirt or debris in there. Try applying very gentle pressure to the lens and see if it retracts or moves.
If it still won't budge, it's probably an internal problem with the mechanism retracting the lens, there's not much you can do but send it off to get fixed.
Cheers!
Mar 27, 2011 | Nikon COOLPIX S570 Digital Camera
Lens is stuck out, makes clicking noise and then peeps and screen states Lens Error, restart camera. But everytime I start it it does the same thing, what can I do
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Oct 30, 2009 | Canon PowerShot SD790 IS Digital Camera
Lens won't close all the way
try cleaning the lens with super glue
Jul 23, 2008 | Sony Cybershot S650 Digital Camera
Lens error 126,1,0,-9
Mine said error code 126, 1, 0-9 but it was just bent so I had to bend it back, now it works fine.
Jul 04, 2008 | Kodak EasyShare C613 Digital Camera
Olympus Stylus 760 problem
I just called technical support and they told me the camera has an internal problem. You have to call them if your camera is still under warranty and send it to a repair center.
Apr 29, 2008 | Olympus FE-170 Digital Camera
Pasotti sergio
The notor system has broken.
Contact Olympus support re repair.
Be warned of the camera is out of warranty the repair will cost nearly as much as buying another more upto date camera
Dec 08, 2007 | Olympus Camedia C-60 Zoom Digital Camera
Olympus Mju 400 error code d: 1E12
the lens is with problems and needs to be changed. doesn´t happen when u connect to computer, because when is connected the lens doesn´t move.
Jan 21, 2007 | Olympus MJU 400 Digital Camera
Error 18
The "E18" error code indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Aug 31, 2005 | Canon PowerShot SD500 / IXUS 700 Digital...
Olympus Camedia C-60 Zoom Digital Camera Logo
259 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
