Question about Maytag Microwave Ovens
Maytag microwave MMV4205BAW interior fan continues to run when door is closed
Microwave is still functional. Cooks as usual. Just can't close the door when finished and food is removed as the interior fan continues to run.
  • Susan Perroni Apr 16, 2012
    Thank you for your help. Unfortunately the micro switches do not appear to be the problem. After receiving your solution, I checked all three switches and they are functioning as indicated (both door open and closed) on the schematic that I found inside the casing.
  • Maytag Master
  • 6,771 Answers
One of the micro switches has malfunctioned, and must be replaced for normal operation.
Posted on Apr 03, 2012
Testimonial: "Thanks again! I was afraid of that. Probably a bad relay but you have to purchase the whole board and that looks to be a $200 part. Guess it is time for a new microwave."
  • John Cunningham Apr 16, 2012
    That would leave the keypad control board as the problem.
    Thank you Susan, you are right the whole board would need to be replaced and cost would not justify it.
SOURCE:
SOURCE: Microwave continues to run when the door is closed
Did you pressed the stop/clear button? or disconnect the micro.. for a couple of hours and try again?
Posted on Apr 04, 2009
localwonder
  • 6784 Answers
SOURCE: After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Posted on Jun 19, 2009
wiringlunati
  • 576 Answers
SOURCE: Microwave GE Spacemaker JVM1650SH05 - The light
The bulb may have blown. It is often under an access panel on the side or back that is held on with a screw or two.
Posted on Jan 26, 2010
MicrowaveSvc
  • 9174 Answers
SOURCE: POwer switch
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix - see this file) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Posted on Jan 31, 2010
MicrowaveSvc
  • 9174 Answers
SOURCE: Fan continues to run when I open the door.
It may be a door switch problem (see this file) or a stuck fan relay on the control circuit board, which we can repair for $39.95 in most cases.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 28, 2010
Why does the fan keep running on a kenmore spacemaster 300?
Check those 3 micro switches in the door latch assembly. A bad microswitch can blow the main fuse. This usually ruins the microswitch.
Nov 13, 2017 | Kenmore Microwave Ovens
Mmv4205baw parts
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer. See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. See our help file on door switches here.
You can find helpful manuals, exploded views and parts lists here.
Our favorite supplier is the Pros here.
Jun 10, 2013 | Maytag MMV4205 Microwave Oven
Advantium 120 not working
see this causes and fix it. God bless you
If the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan.
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout, and the fan, replacing parts that don't pass the test.
Oct 15, 2012 | Maytag MMV1153A Microwave Oven
Why it's not functioning?
God bless you
f the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan. If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout (see the Applaince Controls Fix-It Guide), and the fan, replacing parts that don't pass the test.
If the oven keeps blowing fuses, check for a faulty door interlock or monitor switch.
Oct 02, 2012 | Microwave Ovens
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
Maytag mmv4205bab continues to run after time is up. The fan does not circulate, but it continues to heat.
Our microwave in office won't shut off. It continues to heat and fan is running as soon as we close the door. Tried everything, unplugged, canceled everything. Please let me know what to do.
Oct 04, 2010 | Maytag MMV4205 Microwave Oven
[email protected]
May 22, 2010 | Sharp R-1480 Microwave Oven
Sharp Carousel R-530CW
Hi, I am not sure of the cost concerning the control board, however, it does sound like a control board problem, or a door switch problem, I would need to see the specific unit diagram to know for sure, but many microwaves, not all, but many, have a door switch related to that part of the circuit, usually the fuse would blow at that point, but there again, it depends on the circuit. I would suggest you get the unit checked soon however. Hope that helps somewhat, and thank you.
Jan 24, 2009 | Magic Chef MCB780W Microwave Oven
Possible door adjustment problem
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Or you can return it for replacement.
I would not suggest trying to fix this yourself since it's under warranty.
Nov 21, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
314 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
