Question about Philips Lands Phones
I have 3 cordless telephones with one base station. I took one handset to a shop to buy new batteries. Now it doesn't seem to recognise the base station any more and is flashing "search". Could you tell me how to reinstall this? Very many thanks for your assistance. D. Ader
The batteries were incorrectly installed! Problem solved.
Many thankss
Posted on Nov 11, 2008
HOW DO I DEREGISTER MY BASE STATION?
If you want to replace a handset or re-assign the designated handset number of a registered handset, you must de-register all the handsets and then individually register each handset.
To de-register all handsets:
Press and hold
FIND HANDSET
on the telephone base for about 10
seconds (until the IN USE light on the telephone base turns on and starts to flash), then release FIND HANDSET
Press and release
FIND HANDSET again. (You must press FIND HANDSET
while the IN USE light is still flashing. The IN USE light flashes for
approximately seven seconds.)
All system handsets show
CONNECTING...
The de-registration process
takes about 10 seconds to complete. All handsets show
NOT REGISTERED
when the de-registration completes.
If de-registration fails, you might need to reset the telephone and try again.
To reset:
Pick up the registered handset and then press
/FLASH
Press
OFF/CLEAR
and place the handset back in the telephone base.
-OR-
Unplug the power from the telephone base, then plug it back in.
note:
You cannot de-register a handset if any system handset is in use.
After de-registering, proceed with registering process:
If the handset screen does not show LOW BATTERY
or HANDSET X, you will need to charge the handset for at least five minutes before registering to the telephone base.
To register a handset:
Place the unregistered handset in the telephone base or charger. If
PRESS FIND HS 4 SEC ON BASE
does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
On the telephone base, press and hold
FIND HANDSET
for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows
PLEASE WAIT...
and it takes about 10 seconds to complete the registration. The handset shows
HANDSET X REGISTERED
(X represents the handset number assigned)
and you hear a beep when the registration completes.
Nov 13, 2017 | Lands Phones
I have a KX-TG6700 base station and 4 Handsets. When I have been calling on the handsets I have recently found that there is static on the line. Later I realized that there is problem with the DTMF being...
The KX-TG6700 manual at: http://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdfhttp://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdf
States:
For best performance
Base unit location/avoiding noise
The base unit and other compatible
Panasonic units use radio waves to
communicate with each other.
For maximum distance and noise-free
operation, we recommend the following:
LPlacing the product away from electrical
appliances.
LPlacing the base unit in a HIGH and
CENTRAL location with no obstructions
such as walls.
LRaising the antennas vertically.
LIf you use the handset near a microwave
oven which is being used, noise may be
heard. Move away from the microwave
oven and closer to the base unit.
LIf you use the handset near another
cordless phone’s base unit, noise may
be heard. Move away from the other
cordless phone’s base unit and closer to
your base unit.
Have you considered all these points?
Is there a way you can move the base station to another location in your house to see if the problem get better? I don't beleive your base station is faulty, I suspect interference from something.
I don't think the 2.4GHz set is causing any issues, but you never know, try unplugged it for a while to investigate.
If you do determine that the base station is faulty there probably isn't many options to get it repair other than sending it to Panasonic. May be cheaper to buy a new base station to go with your extra handsets.
Good Luck!
Mar 14, 2008 | Lands Phones
Won't hold a dial tone go new batteries still a problem
Maybe trying to pair the handset with the base station will solve your problem. Look in the manual how the pairing procedure is done for your phone.
If the pairing procedure is done, and the handset finds the base station and there's stil no dial tone, check if the cable from the telephone line is plugged in the base station of the phone and check if the other side of the cable is plugged in the wall phone outlet.
I hope this will solve your problem.
Feb 13, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
CWD4900SE - We have just bought a refurbished extra handset but it has OUT OF AREA on the screen. We have lost our manual - is there something we need to do to get the new handset to be recognised by our...
You shouldn't have to do anything special, just place the new handset into the main base station so it can sync to your frequency.
If that's not working, then the refurbished unit is defective and you should exchange it.
Jan 14, 2010 | Cable_and_wireless CWD4901 Cordless...
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
I can hear, but not talk, on my ATS RA2184BB cordless phone.
Have you tried unplugging your base station and all the handsets?
Sometimes the base station, where the power and the telephone line plugs into needs a reset. Just like a computer sometimes it needs a reboot.
If problem presists, take a regular analog phone and plug it in to the same jack as the cordless phone bas station, and see if it is a cable issue/ telephone company issue.
Mar 19, 2009 | Lands Phones
My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Jan 06, 2009 | Vtech Cordless 6041 Phone
GE duo 21828 cordless telephone english user manual
Press down key until the handset menu appears and press "INT/OK" key
Press up or down arrow key to select the submenu "Resgister" and press "INT/OK" key
Handset display shows "SEARCHING".
Press and hold "page" key on the base station more than 4 seconds until acknowledgment signal is heard
Enter the PIN (default setting = 0000) and press "INT/OK" key
on the Handset
If the input PIN is correct the registration procedure will be completed with a confirm tone.
After a connection is established the name and number of the handset appear in the display
Note : The base will be ready for registration for 10 minutes when the page key is pressed and held for more than 4 seconds.
Please let me know how these phones have performed, are you happy with them. Thanks
Jun 09, 2008 | Uniden Cordless Phone
TELEPHONES LOOKING FOR BASE?
Hi Peg,
First get new batteries. do  go to Radio Shack! Take the original with you and go to Best Buy, Circuit City....Office Max, or Staples and be sure they are IDENTICAL .   Voltage and MH (milliamps)
Thanks,
Bob
Oct 19, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Answering machine
Unfortunately the 4010 model does not have a built in answering machine but does have features to work with your local telephone companies voice mail. If you want to keep your same phones and get a base with a built in answering machine you will need to replace your 4010 base with a 4015 base (up to three handsets), or a 4215 base (up to four handsets). But don't toss out your old base, you can use it to extend your range if you ever use a 4200 series handset that will allow you to register each handset to up to four seperate bases simultaneously to extend the range. You can buy the 4015 or 4215 base only and save yourself some money. You can google Siemens cordless repair or go to the Siemens website to find a few options.
Aug 12, 2007 | Siemens Gigaset 4010 Cordless Phone
Lands Phones Logo
51 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
