Question about Abit SE6 Motherboard
Abit se6 motherboard
I need toknow how to hook up the front usb cbles they are all seperate wires with data 1 + - and so on but it dosnt show me where to start with the positive and negitive connectors andi dont want to ruin it so if anyone has any help it is appreciated i know where pin 1 is on them but that is all
    President:
  • 2,351 Answers
Hi bdb124,
Trying to hook up any USB ports is not an easy issue unless one can include pictures. Click on this link provided. Its a walk through & will help you hook up your USB ports.
http://www.directron.com/installusb.html
Good luck bdb124!
Mike
Posted on Nov 10, 2008
Where does the power switch connect to on the motherbord of a is7 ev12
Abit IS7-E (Version 1.2? I see v2 though)
http://www.baber.com/motherboards/abit/p4/abit_is7_e.htm
Larger photo,
http://www.ebay.com/itm/ABIT-IS7-E-Pentium-4-DUAL-DDR-400-865PE-motherboard-/260838150304?pt=Motherboards&hash=item3cbb2a50a0
Scroll down to about half page. Shows a large view of motherboard.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Motherboard mounted in computer case, the Front Panel is at the Bottom/Right corner.
Rectangular piece of plastic, with two rows of contact pins.
FP101
The Top row is numbered EVEN.
The Bottom row is numbered ODD.
Starting on the LEFT side, going towards the Right; Top row,
Pins 2, 4, 6, 8, No pin 10, 12, or 14. Pin 16. No pin 18. Pins 20, 22, and 24.
If the Pins were X's, and No pin was a Zero -> 0
,it would look like this;
X X X X 0 0 0 X 0 X X X
Going from LEFT side, towards the Right; Bottom row,
Pins 1, 3, 5, 7, 9, No pins 11, 13, Pins 15, 17, 19, 21, No pin 24.
X X X X X 0 0 X X X X 0
A) Pins 2 and 4 are for a Suspend LED cable. In otherwords do not use.
B) Pins 6 and 8 are for the Power On switch
C) Pins 16, and 20; are for a 2-wire Power On LED light.
Pin 16 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
D) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
E) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
F) Pins 15, 17, 19, and 21 are for a speaker.
Pin 15 is Positive ( + ) Pin 21 is Negative ( - )
http://www.elhvb.com/supportbios.info/Archives/MANUAL/ABIT/is7_series.pdf
[Ignore if you are aware;
The above is the motherboard manual, for the Abit IS7-E, and all versions.
It is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above link, it may take Up To 30 seconds, before the first page will show.
(May take a little longer with this one)
A PDF file will not show until fully downloaded ]
Page 25 in the Adobe Reader page number box at Top, is for the Front Panel header pinout.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 23, 2013 | Computers & Internet
I had to change the motherboard as it failed
Look at the front panel of the computer you will see the connections you have. Should be power, reset, power led, usb etc. These are connected to your current motherboard and most times all the connections will be labeled in the case, on the wire connector ends. IE the end that connects to the motherboard. The only exception to this is the usb ports, and they can be hooked up to new usb connectors on the motherboard. Also note, read i said READ the proper way to connect the usb to the motherboard, this is usually a one shot deal, get it wrong and you kill that usb connector.
Apr 24, 2010 | HP Media Center M370N (DM163A#ABA) PC...
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Case wire two mother board
Here is your front Audio guide:
http://www.fixya.com/uploads/images/3C3CD07.jpg
Here is your USB guide:
http://www.marnscda.com/Guide/USBPinMB.jpg
And here is your front Panel guide:
http://www.elhvb.com/mboards/intel/pinout-OEM-Intel-2x9pin.jpg
Let me know how that works out. The front panel guide is rotated 180 degrees however.
May 02, 2009 | Foxconn 661FX7MF-S Motherboard
Abit an7 motherboard front panel wiring diagram needed :)
Front pannel audio is located left of the pci slots
: : : . : : :   thats what it looks like         from left to right there are seven sets of pins 1234567.
3 and 7 should be the pins you want for a standard front panel audio as far as i see in the manual ICEBOX
Mar 22, 2009 | Abit AN7 Motherboard
Abit Kg7-Lite motherboard USB2 pin Locations desperately needed!
Lay case down with the bottom in front of you. Looking straight down at the row nearest the case bottom reading right to left there will be two rows of four pins.
Reading right to left the row closets to the case bottom the first lead is vcc1, next usb1-, next usb1+ and grnd1.
Top row reading right to left is vcc2, next usb2-, next usb2+ and grnd2.
I just replaced bad caps on my kg7 and had to remove the motherboard for the repair so I just reinstalled my front case usb ports.
Help this helps.
anon paranoid
Feb 18, 2009 | Abit KG7-Lite Motherboard
Abit motherboard nf-m2s
Hi chatzmoe, on page 8 of you're manual is a picture & layout for you're abit NF-M2S front panel connectors for LED's.
If you're current manual does not show this, tham download the manual from the link below.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF-M2S&fMTYPE=Socket%20AM2&pPRODINFO=Manual
Main web page for Abit NF-M2S.
Have more questions? Please feel free to ask.
Luck!
Mike
May 08, 2008 | Abit NF-M2S Motherboard
Usb shortage
There's a photo of your motherboard here: http://www.techspot.com/reviews/hardware/abit_vt6x4/ You see the part labeled "USB header for two extra USB channels." That is where you'd connect any additional USB ports. When you say you have two ports on the front of the stack, I assume you mean on the front of your computer case? Front mounted USB are handy, and just about standard on most cases. Just connect the cable from them to that connector and you should be ready to go. If you're not sure which way to connect it, just try one - you won't break anything by connecting it backwards (you'll just have to switch it to get them to work).
Aug 30, 2007 | Abit VT6X4 Motherboard
Abit SE6 Motherboard Logo
60 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
