Question about Matfer 660 Watts 210412 Hand Mixer
Parts needed for Matfer 660 Watts 210412
Need shaft coupling between motor shaft and mixer shaft. any suggestions??
Heritage Food Service Equipment has parts listed as available. www.hfse.com
The motor to shaft coupling will have to be ordered from another stlye motor but will work.
The model to look for is actually listed as Dito-Dean, not Matfer.
Posted on Nov 11, 2008
Professional 600 575 watts beater shaft is loose
If the beater shaft that you attach the beater to is loose in it's housing, then you will need a new planetary for your mixer, it is a relatively easy fix to make, but you will have to order the part before you can effect a fix.
The 600 model has the center shaft attached to the planetary by means of a heat pressure press in. Which means that when the colored rotating part starts to come loose that you have to replace the whole planetary piecec994bebd-6a21-41c8-821e-a90ec9e3ea14.jpg
the piece that the beater attaches to is called the agitator shaft and it will need to be removed and put on to the new planetary when you install the new one. If the agitator is actually the piece that is loose then you need a gear at the top, a pin underneath of the gear, or a snap ring that holds the shaft together in the planetary housing. Go to the kitchenaid address listed here>> http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
when the page opens look on the left side of page and fill in the proper model number (it is on the bottom of your mixer on a white tag), the page will give several choices go to the parts list section and click on that choice for your model number, (you will need the proper part number to order the correct color for your mixer, by following the parts list diagram you will see that there is a very understandable process that you can follow to open up the mixer and replace the planetary, hope that this helps, let us know if you need assistance or if this answered your question
Apr 17, 2013 | Food Mixers
I have a Hamilton Beach Model 727-3. Works fine but I lost the mixing shaft. I ordered a new one for model 727-B (there was no model 727-3 listed). I am having difficulty getting the new shaft...
The part you need for the 727-3 is referred to as an "Agitator". It looks like the mixer shaft for the 727B but it has "ears" instead of "pins" that lock the shaft into the mixer. Same price but different name and part number.
Apr 30, 2011 | Hamilton Beach DrinkMaster Classic...
Won't turn on after first use. 1801 220 watts hand mixer looks like 2562 250 watt mixer
It seems that the mixer is overheating and tripping the thermostat thus preventing further use. I would recommend a thorough overhaul. You will need to carefully inspect all the components, particularly Items the brush assemblies, and the commutator portion of the armature (where the brushes touch the armature), and everywhere else in the motor compartment. Any parts exposed to oil will need to be degreased and dried before reassembly. When you reassemble your mixer, the brushes can only be installed one way. Make sure the brush's concave contact face is resting completely on the armature. If it is turned it 90 degrees too much, it wont' seat properly and the motor will not get any juice.
While your mixer's apart you should check for any other unseemly wear and tear on the gears, etc. You may find more things that need fixing, adjustment or replacement.
You may find it easier to replace the brushes than degreasing them. I recommend using a food-grade grease that you can order online (although I've seen automotive bearing grease used too - your call). If you feel this is beyond your capabilities and will be too difficult to do by yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer.
Dec 12, 2010 | Sunbeam 2562 250 Watts Hand Mixer
I'm trying to find replacement beaters for a Hamilton Beach mixer model #019. My beaters are chipped and rusted so I'm not comfortable using them. I've found a couple of places that used to sell them but...
Check on eBay. Sometimes you will find replacements--even new ones. You'll need the actual Model Number off the tag on your mixer (see link where to find that info).
Search Now for Replacement Parts Accessories HamiltonBeach com
Then search for:
Make Model replacement parts
Jul 22, 2017 | Hamilton Beach Food Mixers
Our Sunbeam Mixer (stand variety) is about 25+ years old and has many miles on it. . About a week ago, while mixing a light concoction it slowed down and then stopped. It started a couple days later...
You will need to search for a repair shop. There are replaceable parts in the speed control assembly that will cause your symptoms when they fail. The question is - can those replaceable parts still be obtained after 25+ years?
May 10, 2017 | Sunbeam 275 Watts 2369 MixMaster Series...
Need replacement beaters
Black & Decker MX77 PowerPro® 220 Watts Hand Mixer Black & Decker MX77 PowerPro® 220 Watts Hand Mixer - User Rating: 4 stars. ... There are no signs of rusting around the metal parts. Overall ...epinions.com/review/pr-Black_Decker_MX77_Mixer/...
Nov 02, 2009 | Black & Decker 220 Watts MX77...
Blade will not turn
motor will hum but no blade turn if bottom seal worn and material leaks into shaft. Rekove drive head and try turning shaft if nio go dissasemble entire unit ,clean and service, replace seals
Sep 20, 2009 | Robot Coupe MP600 750 Watts Hand Mixer
I have disassembled my K5SS Kitchen Aid mixe with all gears removed in order to solve its electrical problem. When I plug in the motor and move the speed lever, there is no movement or sound of the motor...
Unless it sits at the back of the motor behind the vent cover. I couldn't find one anywhere on ours either. Check the motor brushes for broken or badly worn carbons, or collapsed springs. It could be a broken wire at the plug end or something wrong with the speed switch. Some strategic voltmeter sleuthing is required. Try turning the motor shaft while the power is on. It may have a dead commutator segment.
Aug 25, 2009 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
Matfer 660 Watts 210412 Hand Mixer Logo
152 people viewed this question
Top Matfer Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Matfer Food Mixer Expert? Answer questions, earn points and help others
