Question about Panasonic KX-T7630 Corded Phone
Not so much a problem as how do I turn on a feature?
Want to hear a phone ring that previously didn't want to hear and had the ringer turned off in several locations within the office, can I selectively turn on the ringer?
  • Panasonic Master
  • 2,460 Answers
You can, but you may not like it much.
It will take at least one button and I'd use two, or you can dial a couple of codes.. Start with turning on all ringers. Now, when a call comes in, it should tell you what's ringing. We use the x00 numbers, and the system uses IIRC 6xx numbers by default. Or, * works nicely. Dial *7360* on the intercom and you will log that phone out of all groups, or replace the second * with the extension number of the group. In passing *7361(group or *) logs it back in. You can also pick a button and turn on the Log-In feature (PROG 55* ENTER) gets them all.
Now, here's the fun part. When you press that button, it will either be lit or dark. If it's lit, you are logged OUT and your phone won't ring, even if it's programmed to ring. That's good. The bad is that the line light will not let you pick up a ringing call. You have to use the Pickup codes like *4001 for group 1. If you've just dialed the *736 code, you're on your own, because there's no visual indicator.
Also by the above, if EVERYONE logs out...We can tell it in software to not let everyone log out, but your bad luck is that last logged in phone may be the shipping dock that only they can hear.
Of course, pressing the Log In/Out button again will make the light go dark and it will ring like it did before you logged out. A couple words of caution, because it's a great way to drive your installer nuts if you call him out to repair a "no ring." If you screw with the buttons and take the feature out, make sure that you log back into the group BEFORE you delete the button :-) If you happen to program a button, log out, and then delete the button, the TDA will do exactly that! Of course you, or your service tech can just simply clear the extension (*790) and everything drops.
There is a system programming way to make the phone not ring but flash the lights always, that's ICD with no ring or delayed rings of 1-6.
Play with the options if you like. Remember you can't really screw it up too badly since the *790 will undo anything you do...and clear all your forwards.
Wow, too many paragraphs, but I hope you have a clear picture.
Carl
Posted on Nov 11, 2008
How do I turn the volume of the ringer off on Nortel T7316E. I don't want it on 'do not disturb' as I need to take calls/allow them to go to voicemail, but don't want to hear the ring.
Two different options,... Call the extension, and while it is ringing, press the volume down bar until you can no longer hear it ringing. You can also try this... Leaving the handset down, do Feature * 80, adjust the loudness for ringer volume by pressing the volume bar.
Oct 21, 2016 | Lands Phones
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
Jun 25, 2015 | Nortel Networks T7316E Telephone Platinum...
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
Oct 04, 2013 | NEC Dterm DTP 32D-1 Corded Phone
Norstar Meridian how to turn on the ringer
From the following web site:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Jun 15, 2012 | NorStar Meridian M7310 Phone
How do you turn the ringer back on a T7316E Nortel phone? We have several phones that do not ring, we need the feature code to hear the ringing
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310, ...regards John
Mar 14, 2011 | NorStar T7316E Corded Phone
I need to make them ring
First check and see if the ringer is on or the volume is turned up.
1st press Feature *6 Press number keys 1- 4 to hear different ring types
2nd - check your volume (Press Feature *80 press volume key up or down
Jun 23, 2009 | NorStar M7324 Telephone
Uniden 5.8 ghz phone. Can you turn the ringers off and how ?
On most of the phones you just keep pushing the volume down button untill it turns off. On some models there is a "Do not disturb" feature, usually it is a soft key feature so look on the LCD screen. Also, for the person that can't turn the ringer back on, just push the volume up key untill the ringer is at the level you like.
Dec 10, 2008 | Uniden 5.8GHz Cordless Phone
Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
Let me know if this works for you.
Sep 03, 2008 | Nortel T7316E 2-Line Corded Phone
Phone not ringing
Just recently the Innovage LED touch screen phone stopped ringing. It has worked perfectly as a home office phone since Oct. 2005. Cannot find anything in the tiny manual to correct this problem.
Dec 26, 2007 | Vtech VT-9118 Cordless Phone
Phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
May 10, 2007 | Panasonic KX-TG2303B/WH Digital Cordless...
Panasonic KX-T7630 Corded Phone Logo
172 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
