Question about Sony VPL-PX15 LCD Projector Multimedia Projector
Sony VPL PX15
I replaced the bulb in the projector, but I still get a yellow ue at the bottom of the screen.
  • Anonymous May 24, 2009
    It doesn't work.
  • Anonymous Mar 26, 2014
    yellow screen on Sony VPL HS10 Projector
After much irritation at not being able to find a manual that told you how to do this... I found it!
1. Place your projecter in stanby mode
2. Press RESET
3. Press the LEFT arrow key
4. Press the RIGHT arrow key
5. Press ENTER
These steps will work. You might have to make sure that when you are selecting the left and right arrows, that you are facting the front of the projector. When I did this, I did it on the projector itself, not using the remote.
Hope this helps you.
Posted on Feb 05, 2009
Sony Projector VPL-CW255 is showing yellowish tint on screen. I have put in new bulb, changed filter, new cord and still yellow? Any idea what else to do?
Wire ages no matter how many times it's used. You may want to check the amount of nicotine that may be on the lens if there is smoking allowed in the room too. It will add a yellow to orange tint as well.
May 27, 2014 | DS Miller Inc. Equivalent of PHILIPS LC...
I have a Sony VPL-PX15 I get an error saying Backup Battery Very Low. How do I replace it
there is not a Backup battery in this projector
pls check the lamp
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
http://www.lampdeng.com
Feb 26, 2014 | Sony VPL PX15 Multimedia Projector
Yellow spot on VPl x1000 Sony projector screen
one of the three polarizers is burned up It can be repaired
Dec 27, 2012 | Office Equipment & Supplies
Sony projector vpl ex5 yellow display problem
try replacing the bul/lamp.
warning! $200 part http://www.amazon.com/Projector-LMP-E190-VPL-ES5-VPL-EX5-VPL-EX50/dp/B003ISW2KM
May 21, 2011 | Sony VPL-EX5 Projector
Reset option killed the yellow warning to replace the bulb, but didn't reset timer...it's still showing 4,400. I bought new replacement lamp from www.electried.com, but it's showing dark. Is it the lamp or...
The projector's lamp cover might not be securly on or you might need a new one, or the projector has blown a fuse that can be replaced other wise it could be your projector but be sure to contact your sony dealer first.
Feb 09, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
How to fix yellow hue center bottom of picture.what causes this
Most often color distortion is due to the bulb wearing out. Projector bulbs often fade or distort colors before they actually burn out. The other thing you can try is to reset the projector to it's factory settings, which sometimes fixes color issues. It's usually an option in the "settings" area of the menu.
Jan 18, 2010 | Sony VPL PX40 Multimedia Projector
My projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Dec 07, 2009 | Sony VPL CS6 Multimedia Projector
Blue Haze on screen Sony cineza vpl-hs50 projector
I also have the same problem -- the fix is to replace the optical block ( Internal lamp engine ) which is a $1,100 part. I just purchased a used projector for half the price of the part.
Nov 29, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Jan 14, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
275 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
