Question about Imperial IFS40 Deep Fryer
Dean SR142GP will not hold temp
Fryer will not hold at temp. Thermostat is working, but gas valve will not ignite when therm. tells it too. Replaced the gas valve and still same problem. Could the problem be with the temp sensors?
    Scholar:
  • 81 Answers
If thermostat is "closing" and sending power to gas valve, you may have too little mv power. A bad thermopile can cause this.
Posted on May 03, 2009
    Genius:
  • 1,199 Answers
REPLACE TEMP SENSORS
Posted on Dec 06, 2008
Deep fryer pilot is blown out when burners go out after reaching temp
Hi there. Hi limit may be tripping off due to high oil temperature (power supplying the gas valve is connected in series with the hi limit). Verify if the thermostat is not shorted, also please check the thermostat calibration if it is good.
Regards.
Sep 16, 2013 | Frymaster Dean Kitchen Appliances - Others
Pilot lights however when I turn the temp up to where I want it set to pilot goes out. The thermostat makes a ckicking sound when I tune it right before pilot goes out
Hi there.
Verify if the gas pressure fed to the fryer is correct. Check also for errors/ loose wire connections on gas valve, thermostat and hi limit, last possible cause, the thermopile is weak and cannot give enough power to energize pilot and main valve at the same time.
Regards.
Aug 14, 2013 | Dean SR14E Deep Fryer
With thermostat off still lets gas thru
Either the thermostat or the gas valve has failed. Locate and disconnect one of the wires going to the thermostat, if unit continues to heat the gas valve has failed, if not, the thermostat is likely stuck closed (on).
Oct 10, 2012 | Frymaster Dean SR42G Deep Fryer
Unit ( model SR142gp serial 0608MA0448 - propane fuel ) operates as designed, but can not cut flame to pilot with the thermostat. must cut the gas control to pilot to the get pilot flame & pilot...
The pilot light should remain "ON" all the time. It is not intended to ever go off, unless you are not going to use the fryer for several months at a time. Then you can just shut off the propane which will shut off the pilot light flame. It does not cost that much to run the pilot light all the time. About one to two dollars a week.
Sep 11, 2010 | Frymaster Dean SR142GP001 Deep Fryer
Pilot light stays lit when I turn the gas valve to on. But nothing happens when I Turn the thermostat on. Help
The thermostat control is bad, you will need to replace the thermostat switch and everything will work just fine. Basically the thermostat switch is not sending a signal to the gas valve telling to to turn on
May 25, 2010 | Frymaster Dean SR42G Deep Fryer
This fryer has been giving us problems. After we
You can try putting a jumper wire between the two terminals on the thermostat after the pilot is lit to see if the valve comes on. It is less than 1 volt so don't worry. That will tell you if the problem is with the thermostat or the gas valve.
Tom
May 18, 2010 | Dean SM20G2 Deep Fryer
Dean gas deep fryer burner on high will not respond to temp set
The thermostat is likely welded shut. You'll have to change it out.
Feb 25, 2009 | Dean SR14E Deep Fryer
Frymaster gf 14 won't come on
Ok sounds like your problem maybe that the gas valve is set to low. If you have access to a manometer you can put it on the outflow port of the gas valve and see what the reading is. It should be at 4" water column for this fryer. You possibly might even have a faulty gas valve, these will go out sometimes and still let the pilot bypass maintain regular operation. Please comment me back if you need more assistance with this.
Thanks
Jul 14, 2008 | Frymaster Dean FM345EETC Deep Fryer
Imperial IFS40 Deep Fryer Logo
482 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
