Question about Thomson 24WK25U 24" TV
Thomson and LG TV's difficult to switch on
After a couple of months of use both sets refuse to switch on with remote or manually. If they are unplugged and left for a couple of months they start working again. I have to alternate their use. The sets, when switching on sometimes respond with a quick flash of picture before switching back off. At present neither set will switch on. The only AV used is a Phillips freeview box. Both TV's are around 8 years old and this problem has happened for the past 10 months, soon after we had some electrical work in the house. Could this be the cause?
    President:
  • 3,130 Answers
It most certainly could be the cause of the problem. Most of the time when a TV set comes onm then switches off, its a fault in the power regulator circuit. Regulators can go bad all by them selfs, but most of the time, they fail due to excessive AC voltage, and or ppower surges, such as the oin off action of intermittant power would cause. On sets this old, Im not sure you would want to invest the type of cash to repair. Its onlty a guess but I would say a minimum of 125 to repair them? Its a call only you can make. You should go to this link and read this first. http://www.techlore.com/article/10602/ Good Luck Please do not forget to rate this link.
Posted on Nov 12, 2006
SOURCE:
Kod na univerzalny ovladac RM 88E na TV THOMSON
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily...
http://electro-medical.blogspot.com/
Mar 17, 2016 | Thomson Televison & Video
Thomson roc 6407
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device name list in alphabetical order. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 12, 2014 | Thomson Televison & Video
I have chunghop RM-88E,idon't know the tv code of
Have you all of these sets? Wow. Try to to download the user manual to chunghop. It is very difficult to type codes for all of these brands here.
Mar 11, 2013 | Televison & Video
I have a Thomson 20LB020S4 and lost the remote control, now I bought a universal remote which can be used by thomson, but I cannot switch on the TV since this only works with a remote which is programmed...
Dear Sir:
1) Read you user manual and see where is the power on.
2) Get from radio schack one universal remote control.
3) Programmed it. according with the codes coming the literature from R.C.
4) However you can get from the next web: www. fitness.manualsonline. com get you model, etc and download free.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 20, 2012 | Thomson Televison & Video
Lost my TV remote but have a diferent thomson remote .Should the secondone work on my tv
You can find inexpensive universal remotes that work with Thomson here: http://www.electronix.com/remote-controls-c-9.html
May 25, 2011 | Thomson Televison & Video
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
HI, TV Thomson Black DIVA
how to known the service mode for thomson tv blackdiva
Jan 15, 2008 | LG DR-4810 DVD Recorder
No sound
Hi, It seems that the SAP, no audio, distorted audio is a common problem for some RCA units even with the use of the original remote and in your case made more difficult with a replacement remote. Two things you can try: 1. Some say that unplugging the TV set for a long time, a couple of hours at least will do a hard/system reset on the microcontroller inside the TV hopefully resetting set-up the audio (including SAP) to default; 2. contact Customer Support at Thomson and explain your problem; 3. Try going a google on "RCA SAP manual reset"; or 4. Buy an original remote and not another replacement. Hope this work out for you and give you some ideas. Pls post again how things turn up. Good luck and kind regards.
Aug 06, 2007 | RCA TruFlat 27F520T 27" TV
Thomson 24WK25U 24" TV Logo
164 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
