Question about E-Machines (308714) Motherboard
How to pick the right motherboard for eMachines T5026?
The technician told me the problem is the motherboard, power suply is OK, hard drive is too but not sure about the processor.I know that it should be a Micro ATX and a hyperthreading kind, other than that I don't Know.
  • 83 Answers
Heres what i found:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5026
Intel® Pentium® 4 Processor 519
Operates at 3.06GHz
1MB L2 cache and 533MHz FSB
Operating System: Genuine Microsoft® Windows® XP Home
Chipset: Intel® 915GV chipset Memory: 512MB Dual Channel DDR
Expandable to 4GB Hard Drive: 160GB Serial ATA 7200rpm, 8MB cache Optical Drives: DVD±RW, 16x Multi-Format double layer
CD-ROM drive - 48x max write Media Reader: 8-in-1 digital media manager Video: Intel® Graphics Media Accelerator 900 w/DirectX® 9 support
Up to 224MB shared video memory Sound: Intel® High Definition 6-channel audio (5.1) Network: Intel® PRO 10/100Mbps integrated Ethernet Modem: 56K ITU v.92-ready Fax/Modem Peripherals: Premium multimedia keyboard, 2-button wheel mouse, amplified stereo speakers Ports/Other: 7 USB (1 in Media Manager, 2 in front, 4 in back), 3 IEEE 1394 Firewire (2 in front, 1 in back), 1 VGA external connector, 1 serial, 1 parallel, 2 PS/2, 5 audio (2 in front, 3 in back
If you need to replace the motherboard, it is most likely proprietory which means it can only be from emachines so you can request an RMA at the link.
Posted on Nov 10, 2008
How do i take the top cover off a emachines t5026?
Hello cw robin, hi, you need to remove the power supply out of the casing. loosen the side cover screw at the back left side. side of, reveals the power supply box, Now remove the 4 screw on the Fan exhaust side. There is a release lever on the bottom of the power supply like a ball shape lock, press it and it releases the power supply box. remove the connections on the motherboards and drives. Power supply out, there are small screw on the power supply box, remove it. open and you have now access to the power supply board.
Dec 06, 2010 | E-Machines Emachine T5026 power supply **...
I have an emachine t5026 that won't turn on. It
There can be two problems with your PC. either the power supply is faulty which is highly probable, and the other is that your Motherboard maybe faulty or both things are faulty. Try replacing the Power supply first. It should solve your problem.
May 15, 2010 | E-Machines Emachine T5026 power supply **...
Emachine wont start
I just had the same problem. Try replacing the battery on the motherboard, that seems to have fixed mine. The number on the battery is CR 2032.
May 11, 2010 | E-Machines Emachine T5026 power supply **...
I have a T3626 emachine that I replaced the drive.
check all your ground screws on the motherboard. If that doesn't work try booting it up with out the hard drive. if that doesn't work, pop out the BIOS battery and unplug your computer, let it sit for about a min. and put the battery back in and restart.
Sep 18, 2009 | E-Machines Emachine T5026 power supply **...
Help installing new HDD
chain the drives. use the second plug on same cord first drive is plugged into
May 28, 2009 | E-Machines eMachines Desktop PC
T5026 won't start up
Unplug the power cord, open the computer and disconnect all the power cables (the cables going from the power supply to motherboard and drives). Then reconnect the power cord and see if the light on the PSU comes on, if so disconnect the power cord and plug in the motherboard connectors and continue connecting components one by one to determine which may be the problem. If no power light with everything disconnected then the PSU needs replaced.
Jan 03, 2009 | E-Machines Emachine T5026 power supply **...
Emachine T5026 installing a new hard drive.
place the harddrive over or under the old drive.
a IDE cable most be connected to the harddrive and to the motherboard.
and a 4-pin power cable most be connected.
CS.
May 18, 2008 | E-Machines eMachines Desktop PC
E-Machines (308714) Motherboard Logo
1,417 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
