Question about Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
Acer 4520 cd/dvd driver problem
My cd/dvd drive is unable to detect any cd/dvd.there is no icon for cd/dvd drives in 'my computer' .device manager also doesnot show the cd/dvd drives.wat should i do?
  • 6 more comments
  • hafizsabri82 Dec 16, 2008
    no icon in my computer
  • ambermelo11 Dec 21, 2008
    when i go to the current control set class, then to the other file with all the long numbers and letters, it says the data for default as "value not set". When it should say DVD/CD ROM. What should I do??
  • Anonymous Jan 22, 2009
    missing cd drive letter
  • Anonymous Jan 28, 2009
    missing cd drive
  • rama2009 Feb 16, 2009
    Hi!
    Last week I was unable to use my DVD drive as it had stopped functioning. On inspection an ACER service recommended a replacement. Even after installing a new one, I am unable to write or read DVD using my DVD drive. My model is Acer Asprire 4520 Laptop, running XP SP-3, 3 Gb RAM ( 1Gb Acer, 2Gb Transcend), 160 Gb HDD.
    Would highly appreciate any advice or a suitable solution.
    Thanks in advance
    Rama
  • Anonymous Apr 07, 2009
    I have the sme problem, in my computer it show no icon for the dvd-drive. the dvd slot can be ejected, but after i put any cd's or dvd's, nothing happen.
  • Anonymous Apr 20, 2009
    5 of my classmates have the same problem with acer 4520. undetected dvd drive from BIOS and also from windows. acer centre suggest us to replace the motherboard. what kind of **** laptop is this? nearly 1,5 years and most of us have the same problem. acer ****. is there any other alternative?
  • Anonymous May 18, 2009
    I have the same stupid problem.. i have tried everything.. formating hardisk, installing fresh windows.. tried to update chipset.. but it seems nothing works. I read about deleting upper & lowerfilter in Registry editor, but mine doesnt have any upper or lower filter!
    I'm so lost.. i guess I have to forget about using my CD/DVD driver.. **** ACER!
The same problem... I have installed windows 7 for repair one problem with screen, that came in black in some times. It solved, but the dvd rom not work as the sound. Not detected in BIOS, and device manager in win, i dont now if try to update the Bios, that repair a lap in acer One, but it will be do carefully.
Mismo problema, instale win 7 para reparar la pantalla, ya que por momentos se ponia negra, se resolvio, pero el dvd y el audio, no los reconoce, como si no existieran los dispositivos. Quiza intente actualizando el driver, pero si fallas adios lap... jeje $%·&& Acer...
Posted on Jan 16, 2010
    President:
  • 1,257 Answers
Follow this article to fix the issue:
http://support.microsoft.com/kb/314060
Posted on Apr 23, 2009
  • Deeps . Jun 27, 2009
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    issue..
    http://www.windowsguru.org/solutions.htm...
  • ctchuah4828
    ctchuah4828 Dec 19, 2012
    no icon in my computer.
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)" . You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Nov 16, 2008
I have acer aspire 4520 my dvd rom not browse cd driver is instelled and icon once put cd capcitey of
Your DVD Rom drive is faulty, you will need to go to a computer shop or an online auction site to buy one thats compatible with your laptop after you get this through the post on the back of your laptop will be a single screw with a picture next to it that looks like 3 Cd's by taking this screw out your DVD Rom drive will come out giving you access and to replace it.
Jul 07, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Hi, i have problem with my acer aspire 4520. sound card not detect but some time detect. dvd-room not detect. please help me. thank's you
For the sound card issue, try resetting the default BIOS settings, the re-installing the sound card driver from Acer's website
for the DVD issue try re-seating the drive then run this tool
http://www.fixya.com/support/r6169039-cd_dvd_drive_disappears_in_windows
Jul 05, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Icon of DVD/CD ROM driver of Acer Aspire 4520 doesn't indicate in My Computer pannel and as a result I can't work with the DVD/CD ROM.Please help me.
if you want a shortcut so to get to your cd/dvd's
click start click on my computer you will see your cd/dvd drives right click on the cd/dvd drive you should create shortcut another message will appear windows cannot create short cut here do you want it to create one one your desktop another way to get the cd/dvd drives
click start all programs accessories you will see windows explorer in the list click to open up then on my computer you will see your drive/s click on cd or dvd
you could create a shortcut for windows explorer by right clicking on it send to desktop to create shortcut if you mean that you cant see your cd/dvd in windows eplorer
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
hope this helps
Jun 21, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer 4520 unable to read the CD DVD ROM drive. When it is starting it does detect it, but after it enters Windows it doesn t even show up on the Device Manager. Actions taken: Restore...
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
or if these fail to resolve the problem
It could be a problem with the lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected hope this helps don
Mar 13, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I am using Acer 4520 Laptop. Whenevr I tried, the DVD RW drive is not at all detected by the system. Even when I have updated to Windows 7, there is no result. What is the reason and what is the solution?...
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 07, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I have a Samnsung SM-352N DVD CDRW Combo drive. But recently the drivers have got corrupted and I am unable to get back my DVD combo drive to work. In the Device Manager, the DVD CD RW drive is shown with...
control panel admistrive tools,computer management,device manager scroll down cd/dvd drives you should see a yellow question mark? right click to reinstall drivers or right click select enable or properties then general to troubleshoot or region select 4 you might uninstall reboot then reinstall
hope this helps
Oct 02, 2010 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My cd/dvd drive is unable to detect any cd/dvd.acer aspire 4520
I do have the same problem, my laptop doesnt detects the DVD writer, checked with the acer support, asked me to check the motherboard and may need to change that.
Jan 31, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer 4520 DVD driver problem
try to update ur BIOS by install this update from here
ftp://ftp.work.acer-euro.com/notebook/aspire_4520/vista/Bios/3632.zip
Jul 25, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Try to use another DVD. you told you tried you old DVD from your toshiba. maybe is not compatible.. try in another.. then use your DVD in another laptop if the same from problem.check your board and DVD connection...if this under warranty bring to warranty..
if in Bios also can not detect this is hardware problem...
May 28, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My laptop can play cd & dvd but can only burn cd and not cvd
If you detect that your driver is missing, I'd first open my Control Panel, and open your systems icon.  From there you'll go to the Hardware Tab and find Device Manager.  Inside the Device manager lists all of your computer devices.  Look for one called DVD/CD rom drives and check to see if it has a triangluar explanation mark next to it.  If it does, then you can right click on the cd's name, and choose update driver. When you open that a window will appear asking you a question about finding the driver.  Choose yes this time only, and click next.  Then click install software automatically, and click next.  Windows will look for the most current driver for that file.   The other option is to go to Acer and download the driver from their site and install it.
Hope this helps.
Mark
Dec 02, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Logo
10,658 people viewed this question
Brian Sullivan
Brian Sullivan
