EASYCAM PRO HO98064 Have installed with CD 2x's but computer will not recognize driver or softward even though wizard says it is installed. Been to control panel, an unknown device is sitting there but shows not installed
1st You download Webcam Driver.
Drivers and softward wont installAfter this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
SOURCE: EasyCam Pro (HO98064)
Try a different driver if your not happy, remove cam and uninstall driver again through add/remove programmes. When you re connect use a different USB port if available. http://www.jascoproducts.com/cgi-local/SoftCart.exe/online-store/scstore/pro/computer_software_cams.html?L+scstore+gjlg2202ff442544 Sometimes the frequency needs to be set at 50HZ, the same as an Eye toy when it's used as a web cam, as the drivers are usually multi country.
SOURCE: It doesn't work in my new laptop
A code 10 generally refers to a peice of hardware the is faulty. Assuming all the usb ports have been tried and you have tried on another pc if possible, the camera is not able to start due to a fault, not a software problem. If the camera does work on another pc then the driver you have installed is not suitable for your operating system for the camera to be recognised in Windows, especially if it's Vista as there are still problems and sometimes a WIN XP driver is the answer.
SOURCE: GE EASYCAM DRIVERS FOR MAC
i found a solution!
go here and dl the macam.
http://mac.softpedia.com/get/Drivers/macam.shtml
it tells you how to use it w/ other applications as well!
SOURCE: GE Easycam Pro Installation
http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip
this the ONLY driver ive found that works. i searched for HOURS!!
